booo
My new (to me) mondeo is making a metallic squeal on starting and also vibrating at 1.5k revs.
2L 130 bhp tdci on a 53 plate and 80k miles
DMF? I think so
booo
DMF? I think so
You're having no luck with cars at all are you!
Does it start or does the motor fail to engage and squeal/squak? Does it vibrate at cold or when warm too?
Parts for a dmf with clutch (only about an extra £80 so worth doing at the same time) are about £350 plus fitting.
Could be - my focus has apparently got a problem too - my local garage said c. 800 quid with ford parts or a few hundred less with 3rd party parts. Fortunately mine's not causing that much trouble yet so it doesn't need doing immediately.
steve
starts first time but with a horrible noise for a couple of seconds. Vibrates when warm
Should've said prices will vary a fair bit. The official way to do it involves splitting the gearbox and taking it off completely, it's quite possible (tho a bit awkward) to do it with the box saving a lot of labour time if they know how.
where did you have yours done?
I read in a mechanic's trade rag recently (look, I was bored all right?) that Valeo now supposedly make a replacement normal clutch which has similar characteristics to a DMF but costs a lot less.
Doesn't sound great, the starter noise is the biggest sign normally as it is the material of the dmf disentigrating and blocking the connection. It would normally be worse when cold though.
Do you have a friendly/local/regular garage?
Didn't get mine done but got a quote from my local garage (who I've used for years) of about £500-600.
I suspect hot fiat might be talking about a solid flywheel to replace the dmf. I wouldn't go down this route as there have been instances of cranks snapping due to the increased vibration.
kind of but would appreciate any recomendations.
What sort of time frame am i looking at form now as the noise has just starte dthis afternoon until its totally ****?
Mine's been arseing about through the last 2 winters - only really a problem on startup though, no noticable vibration. It's fine during the summer, then starts mucking about again when it gets cold.
I don't have a picture of a piece of string
The problem is that if it is on it's way the extra vibration isn't great for other bits of the engine.
My local garage here in shef is capel motors 0114 2854449. Tell Mike I sent you and ask him for a price. He's sound and won't rip you off.
Mike - what a nice bloke
ringing back in 10 mins with a price
Yup he really is!
Its this kind of thread that makes me want a dit bike rather than a car.
They may eat piston rings every 50 hours,
Need the oil changeing every other ride,
Cost more in chains, sporckets and tires than fuel.
But at least its all dirt cheep and DIY!
quote 1
starter - 98
clutch - 103
slave 130
fly wheel 300
240 labour
all plus vat
Yikes. My quote was just for dmf thinking about it so saves a bit, no starter, slave etc.
Time for a ring round a few places it seems!
Private sale I assume? Even with this if you asked about faults and they said none you still have some case. Might be worth calling them?
not your mate, that was grindleford
Yikes indeed - do you really need all that lot? Mine was for DMF + clutch, but it's probably a bit of a stretch for you to make the trip down to Yateley MOT.
Lets see what the nice man mike can do then
The link I get is to a clutch kit not a DMF.
booked in for monday - £660
Told you he was good
Including vat?
no plus vat i think - where is he btw? what road?
http://Www.eurocarparts.co.uk for parts then take them down to somewhere in town to fit. I like bows garage in sheff - google em! They're great
Ok, too late! For future reference, bows are good
Take the starter off and check for metallic dust.
Squeals could be squeaky belts?
It should always be cheaper to get the garage to get the parts as they'll get trade discounts off the list price that you won't if you just walk in as a random.
not a squeal as such more of a metallic noise if that makes sense. Its the vibration that (imo) is the death knell
gota get it fixed for friday
ya right mate
Result hopefully - the dealer will replace the clutch etc and split the bill 50/50
new clutch and fly wheel on
pick up later. Hope all is well
Don't keep it too long.
I - until last Friday - had a 52 plate TDCi LX like yours (albeit with 145k on the clock). I had DMF probs, wheel bearings wearing out, then endless problems with back brakes etc...
Basically, despite being an excellent car to drive, it got to the stage this year where I was paying out more on parts than the value of the car. Sad to see it go but glad I've got a newer car that isn't going to surprise me with something else wearing out every other month.
what did you get to replace it?
Have you picked it up yet rob? Isn't mike great. His default position does seem to be playing solitaire while smoking a fag in his office tho
Civic 2.2 cDTi ES
cue endless abuse of how these are so much worse than Mondeos etc etc
