I am confused, what I thought was a simple job has turn into a mare
Decided to swap from 2 to 3 rings up front, bare in mind when reading this the bike was setup and working perfectly shifting from the inner to middle ring.
I installed a new chain
Set the lower stop with the chain on the inner ring and largest cog, chain just touching then backed off
Clamped the cable, once the cable is clamped the shifter is hard to shift and doesn’t engage properly. Also the lever doesn’t return, I assumed the spring had gone.
Loosened the cable and checked the shifter which shifts freely and the lever returns.
After further messing over the week, I have managed to get it to run on the inner and outer rings. That is when I push the lever its still stiff, the chain completely misses the middle ring straight to the outer and the lever still doesn’t return properly, I went round the block and it seems stable.
I am at a loss why its pulling so much cable, why its so stiff and why it should change so dramatically
Please help, its doing my nut
