Maxle conversion?
[Closed] Maxle conversion?
[#1758869]
I have a pair of Rockshox Revelation Uturn 2009 forks, currently ran on QR hope skewers...how do I convert to 20mm maxle, or can it be done at all? Total noob question i know, mechaincals are not my forte.
Posted : 01/07/2010 2:38 pm
You can't not unless you replace the fork legs.
Posted : 01/07/2010 2:39 pm
Replace lowers or get some new forks.
Edit...dammit too slow.
Posted : 01/07/2010 2:41 pm
thought not...bah!
Posted : 01/07/2010 2:42 pm
Nearest you'll get is a solid 9mm axle. Even then, depending on the hub, you may need to change the bearings and hub axle. IF the hub design allows you to do that.
Posted : 01/07/2010 2:59 pm
A bit like this.
http://www.flickr.com/photos/pondering_panda1/2293528567/sizes/z/in/photostream/
It provides me front-end stiffness that is as good as my pikes. The only problems is you have to remember a 15mm spanner wherever you go!
Posted : 01/07/2010 7:15 pm
