Mavic 717 + 2.35&qu...
[Closed] Mavic 717 + 2.35" High Roller = death?
[#3229498]
Will a 2.35" High Roller (and a 2.25" Crossmark out back) on Mavic 717s result in death as they roll off the rim at the first corner or should I just be getting some more suitable tyres for my new build rather than using whatevers in the cellar?
Dave
Posted : 10/10/2011 12:39 pm
I run 2.35 Fat Alberts on my 717 front tyre and they've not rolled off the rim after a couple of years of usage.
Posted : 10/10/2011 12:48 pm
Never had a big tyre roll off a narrow rim, even with my monkey weight swinging about the bike.
Posted : 10/10/2011 12:50 pm
 GW
No. (well, not if you remember to put a tube and air in them anyway) They'll just be a little rounder profile
No, 2.35 High rollers aren't that wide or deep for 2.35. I've run them on 717's and now on Stans Olympics. Similar widths and no problems with either.
this combination has been trailmonkey tested and approved.
you will live
2.35" high roller = 2.1" 🙂
Posted : 10/10/2011 12:53 pm
I rolled a 2.25 Racing Ralph off a 717 once on the rear. That was with 30psi, so not under-inflated for my 11 stone. After that I changed the rim for a Salsa Delgado. Loads wider, hardly any heavier and tough as something very tough.
Posted : 10/10/2011 12:56 pm
You shouldn't do. I've run 2.25" tyres quite happily on 717s before and the 2.35 HRs come up quite narrow. As others have said, the profile will be a little rounder, but that's not necessarily a bad thing.
Enjoy!
Posted : 10/10/2011 12:57 pm
Death. Fo' sure. 😉
Posted : 10/10/2011 12:59 pm
(checks pulse)
apparently it's ok.
Posted : 10/10/2011 1:00 pm
no death.. 🙂
I run 2.35 highrollers on 717's at 30 PSI with no problems at all 🙂
Posted : 10/10/2011 1:02 pm
2.35 HRs are most excellent on EX521s
Posted : 10/10/2011 1:32 pm
Cheers all. I'll do that then.
Will report back if I die.
Posted : 10/10/2011 1:47 pm
 Taff
2.25 is fine but feels wierd, 2.5 will roll off!
Posted : 10/10/2011 1:54 pm
I've got a 2.35 HR on my rear DT 4.2.
Feel's very wierd, but hasn't rolled off yet, maxxis come up quite small and I was running it quite hard to keep it rolling quick as it was a similar "what happend to be next to me while building the bike" tyre choice.
Posted : 10/10/2011 2:06 pm
They'll be fine, don't worry.
Posted : 10/10/2011 2:19 pm
mine have been fine for ages apart from te time i did a trailside punture repair and forgot to ensure the bead was properly seated all the way round. this led to the bead popping out of the rim on a hairy old descent, less than ideal. operator error though, it's a nice setup to ride.
Posted : 10/10/2011 4:56 pm
