Oops. Was carried away with bidnapper "testing" & appear to have purchased a fork off ebay. Honest love.
Anyway, it's a Maverick SC32. Will I need a Maverick specific hub or will a regular 20mm bolt through do the trick?
U need an expensive maverick hub, so best u just sell the fork to me
24mm axle innit
Was it from surplus bike bits?
All is not lost if you run hope Pro2's there is an adaptor auailable tp make the hub Maverick compatable
@ Monogramman... what was your experience with Surpluss bike bits? I nearly brought from them this summer.
Ha, i tried to bid on that but the seller had me blocked for some reason, probably because some bint once negged me and i am not 100%.
Let me know if you dont want them and i will pay what you paid for them.
Cheers all - will see what they're like when (if?) they arrive.
No experience with them - I was bidding but lost out.
Little bit noodly (pads always end up rubbing the rotor).
Super easy to home service and fettle (you can mess around with the shim stack to change how they feel).
You can put MAHOOSIVE front tyres on em.
They can be converted to take clown bike wheels.
Spares through Tim at sideways now.
You must log in to post.
