Maths question
[Closed] Maths question
[#1847366]
If I had a list of numbers, some positive, some negative and wanted to add them together, ignoring the sign, is there a mathematical term for the result???
For example:
-1
-5
+2
+3
11
Or has my distant memory of A Level maths let me down?
Posted : 30/07/2010 2:51 pm
The sum of them?
Posted : 30/07/2010 2:52 pm
'wrong' ?
 MS
You wont be 'adding' them if they are different signs to get that answer.
Can I ask why?
Posted : 30/07/2010 2:54 pm
somethingion of the absolute values?
Posted : 30/07/2010 2:55 pm
sum of the magnitudes?
|-1| + |-5| + |+2| + |+3| = 11
Sum of the square roots of the squares?
Posted : 30/07/2010 3:02 pm
Absolute Values - that's the term I was thinking of...
Basically have a whole load of misprocessed entries I and want to measure the total ****-up rather than netting them off and making it look better than it is...
Much appreciated bristolbiker
Posted : 30/07/2010 3:04 pm
'Sum of the total ****-up' sounds way better to me 🙂
Posted : 30/07/2010 3:09 pm
I win!!! 😀 If you have the data electronically, Excel has an absolute function, so you can sum the column/row as-is or sum the absolute values and then see the difference
Posted : 30/07/2010 3:30 pm
 Pook
why do i get -1?
Posted : 30/07/2010 3:32 pm
The absolute value is also known as the modulus of the number.
Posted : 30/07/2010 3:35 pm
