I’ve got an attached garage that I want to turn into a man cave for my bikes. It was built in the late 60s, flat roof, single skin. I was planning to insulate the walls with Celotex or equivalent and line with plywood. Do I need to use plasterboard instead for building regs? Plywood would be preferable for screwing things to.
Is it worth using Celotex for the roof? I’m going to insulate from underneath (I believe that insulating a flat roof should ideally be done from the outside but I don’t fancy ripping up a working flat roof).
The door will be lined with Celotex and I’ll draft proof it as best I can. I suspect that’ll still give me a reasonable flow of air to deal with any damp.
Any suggestions for the floor? Plywood seemed a good choice there too.
