Mac expert needed
[Closed] Mac expert needed
[#3443811]
My refurbed mac book pro starting playing up and it was still undre warranty so i sent it back to be fixed, amongst other things they replaced the keyboard, but it's been replaced by one with a slightly different layout, so the keys now don't do what they say! I emailed the shop back to ask them if I can change this via a setting somewhere and there helpful response was google it! I've tried that and failed, do any of you know?
Posted : 09/12/2011 2:22 pm
which keys specifically?
Posted : 09/12/2011 2:26 pm
The top level navigation, sound, brightness, etc etc
Posted : 09/12/2011 2:35 pm
phone up again and get them to tel you what to do, or send it back. 'Google it' from tech support is totally unnaceptable!
Posted : 09/12/2011 2:37 pm
AFAIK the special function keys are standardised on all mac keyboards now - even international ones - so I've no idea what is going on, sorry! But as said above, send it back and get them to fix it properly!!
Posted : 09/12/2011 2:49 pm
is it not a case of using the 'fn' function button in the bottom left to activate the function keys instead of the expose/brightness/media keys etc?
Posted : 09/12/2011 2:59 pm
ah, if that is the problem there is also a setting you can toggle under "Keyboard" in "System Preferences". I thought you meant the special function keys had been swapped around!
Posted : 09/12/2011 3:06 pm
If that was done under AppleCare it'd be back to the fixer for my money - I'd expect the right keyboard to be put back on!
They are responsive to measured calm pressure - I got courier collection and delivery out of them by being firm but polite.
Posted : 09/12/2011 3:13 pm
This was my keyboard
which was swapped to this
Posted : 09/12/2011 4:16 pm
i would reinstall the OS. this might then recognise the keyboard. i presume the HD was left as it was when you sent it for the reapir.
Posted : 09/12/2011 5:41 pm
You need to reinstall OSX to change keyboards?
Hell fire, and you lot criticise Microsoft?
Posted : 09/12/2011 6:09 pm
Which OS are you using? A more upto date one might recognise the newer layout.
Alternatively this might help:
http://pqrs.org/macosx/keyremap4macbook/document.html
Posted : 09/12/2011 6:14 pm
I'd get back touch with them as they clearly haven't fully repaired it.
Posted : 09/12/2011 6:21 pm
