M4 NUmber 3 Caliper...
[Closed] M4 NUmber 3 Caliper stuck "on"
[#3028470]
Just bought set of M4 brakes off of ebay, a Number 3 and a Number 8.
The Number 8 seems to be working fantastically, but i pulled the brake lever on the Number 3 once and now two of the pistons are stuck in the "on" position constantly...
I am new to hope brakes, what might be the cause of this and the potential remedy, at home if at all possible
James
Posted : 08/08/2011 2:18 pm
Sticking pistons, probably just in need of a strip/clean and rebuild with some silicone grease.
Posted : 08/08/2011 2:27 pm
as above, or dribble some brake fluid (or silicon grease/spray) on the pistons and work them backwards and forwards (using the lever and a screw driver) may sort em without the need for stripping them just yet.
Posted : 08/08/2011 2:30 pm
See [url= http://steveukmtb.wordpress.com/hope-caliper-overhaul-minitrialsm4v2m6/ ]this guide[/url].
Posted : 08/08/2011 2:35 pm
i will give that a go later when i get home,, before i have to take it all apart...as much as i want to at some point to fully understand where everything goes.. a friend of mine also said it could mean there is slightly too much fluid in the system?!?
Posted : 08/08/2011 2:36 pm
If it was over-filled, you wouldn't have been pumping the pistons out in the first place. If they can travel forward, they can travel back - assuming that the seals are doing their job. Over-filling would only cause the pistons to remain extended if the fluid were heated (from prolonged braking).
Posted : 08/08/2011 2:48 pm
when you strip the caliper down, and remove all seals, they clean up very nicely in the dishwasher.
i have a number 6 caliper if you need it - pre-2010 boxxer mount.
Posted : 08/08/2011 3:28 pm
