Long shot, what sub...
[Closed] Long shot, what subwoofer with a neutrik conection?
[#1231744]
OK, I know I could F off to AV forums, but lets just pretend I love this place & respect the advice I get (reading between the dross).
I have Keff eggs & an old REL Q100e sub, but I want a tighter deeper bass, the main problem is I don't want to rip up the woodern floor to lay new cables, so a neutrik connection is a must at this point, so fire away, what's my best bet?
Cheers in advance.
Posted : 17/01/2010 10:49 pm
REL Quake does it for me, try differant positions in the room
Posted : 17/01/2010 10:55 pm
The touble is the cables are run beneth the wooden floor, so I can't mess with possitioning, just tweak the settings, that & the room has to be wife freindly 🙁
To give you an idea the sub is in a corner opposite the eggs, not ideal...
Posted : 17/01/2010 11:01 pm
What Neutrik is it, Speakon? You should be able to get an adaptor to avoid limiting your choice, or just rewire the cable in situ (unless you've got a plate in the wall).
Can't help with the sub really, as I don't like them. Got a £1.5k sub as furniture at the moment, found it hard to integrate properly and eventually gave up. You just need to get proper speakers 😉
Posted : 17/01/2010 11:11 pm
i think Cyrus n-subs have a Neutrik con.
Posted : 17/01/2010 11:16 pm
Cyrus don't make a sub as far as I know. If you mean the Naim n-sub, it has phono low level and 4mm high level inputs. Neutrik is a connector brand, rather than a type of connector. They make DINs, phonos, XLRs, Speakons etc.
Posted : 17/01/2010 11:38 pm
my (v little use) Rel Strata III, its cherry maple, want to see a pic?
Posted : 17/01/2010 11:55 pm
Can't you just remove the connector and rewire it? It'll be easy to do (the Speakon ones i've done before are, anyway).
Posted : 18/01/2010 12:15 am
 Rio
In the interest of domestic harmony I recently had to replace my REL sub with something smaller and went for one from [url= http://www.mjacoustics.co.uk ]M J Acoustics[/url] - I think theirs all have neutrik connectors.
Posted : 18/01/2010 12:26 am
Thanks all, anyone have opinions on BK subs? they seem good value & use the same conections as REL, so might be worth a punt.
Mr Nutt, feel free to post a pic, oh & a price 😉
Posted : 18/01/2010 11:12 am
Very pleased with my BK XLS200. Can't fault the build quality and the sound is a big step forward from a (more expensive) Monitor Audio sub that I was using before (failed and wasn't economic to repair).
I did a fair bit of research into building my own sub on the basis that they're very simple beasts - a good speaker, a good (simple) amp and a well made box is about it. Looking at the cost of the parts there was negigible saving against what BK charge. The same speaker unit appears (rebranded) in subs costing twice the price.
The only drawback is that they lack an auto-on/off circuit. The one on my MA sub wasn't great (it still ate a fair bit of power when supposedly switched off) anyway and i now run the BK off a 'standby saver' type thing on my TV.
Posted : 18/01/2010 3:45 pm
Oh, and compare the MJ Acoustics to the BK subs. They're built by BK the with the same drivers. The MJ versions have more 'features' but the equivalent BK has more power (and costs about 50% of the price).
MJ Reference 200 = 200w at £729 vs BK XLS 200 = 275w starting at £302
Posted : 18/01/2010 8:30 pm
Thanks for that simons.
Posted : 19/01/2010 8:15 am
/should really dig his poor neglected sub out for a photo shesh
hows £300 sound?
Posted : 20/01/2010 8:16 pm
