Learning to jump
[Closed] Learning to jump
[#2281604]
So I've had the day off today and took my bike to the woods for a little mess about. I thought I'd try and put some of the stuff I've read on here in to action and learn to jump. Only started off small and filmed it so I could look back at my technique. Thing is I don't really know what I'm looking for. I was going for 'heels down' and looking toward where I would land rather than the lip. Any further tips or critique looking at this? And I mean the riding, I know the video is shit! Particularly why I ended up on my head with a broken bike on the last one....
Posted : 13/12/2010 9:31 pm
 jedi
nice drop technique per se. you drop your head and sometimes pull which makes you turn off the drop. you need to film the take off so i can see what you're doing pre air.
Posted : 13/12/2010 9:48 pm
heels down sounds odd for jumping, works ok on rough downhill but I dont do it when I do jumps.
Posted : 13/12/2010 9:53 pm
 Pook
is that that little jump in Endcliffe park? And you had a day off to go biking AND DIDN'T TELL ME. Git.
There's a little jump in Stainburn that's perfect for practising this kind of jumping
Posted : 13/12/2010 9:55 pm
sheffield eh?
you'd be better off pedalling up the hill for 15mins - and playing at the Bolehills bmx track.
Posted : 13/12/2010 10:02 pm
Thanks! So look as far ahead as I can? Yeah I'm definitely landing turned sometimes. Will do another one for you next time I can get out in the light!
Posted : 13/12/2010 10:04 pm
 jedi
heels down is required as you push into a drop/jump to make sure you are under rotated and don fall forwards nor kick the pedals/bie away when you feet point down in the air
Posted : 13/12/2010 10:07 pm
Pook - you not started working again now? I procrastinated all day and then just managed to drag myself out of the door before it got dark
I'm not sure I'm ready to be falling off in front of teh kidz at Bolehills yet!
So heels flat? I was loosing the pedals when I tried that (unnerving in the air!)
Posted : 13/12/2010 10:08 pm
Apparently not accodring to Jedi, I cant say i notice having my heels down intentionally. Saying that, Im a true natural a jumps
Posted : 13/12/2010 10:09 pm
 Pook
No I'm not - starting in jan. Come on skype for two mins
Posted : 13/12/2010 10:10 pm
I'm far from a natural!
Posted : 13/12/2010 10:13 pm
I'm interested in this one, learning to jump too.
I find speed helps, I was trying to get 'radical air' around Lee quarry on the weekend. If I didn't have enough speed it felt like I was pulling too much on the bike and landing with the front wheel at an angle. Like I was trying to force it. If I had a bit more speed it felt like the bike flowed more....if that makes sense?
From the little I know you get into the attack position with elbows out and bent, pump into the ramp, look ahead and hope for the best. I'm sure there is more to it but I have yet to learn.
I found all the jumps on the link down to Lee quarry to be do-able baring these in mind and having some speed.
Posted : 13/12/2010 10:15 pm
 jedi
you dont pull!!! thats why you land with the wheel turned or you fall out the side door 🙂
Posted : 13/12/2010 10:22 pm
bolehills bolehills bolehills bolehills.
it's full of 30yr olds falling off, learning to jump, working on lines.
just ride around at first, find a few projects, work on them, you can't fail to make rapid progress.
Posted : 13/12/2010 10:30 pm
It gets confusing, I have read so many threads and tips on learning how to jump.
Some people say they pull up on the bars a bit! I have to agree with you Jedi. My limited experience, this weekend included has taught me that pulling is a very bad idea!
from what I can gather it is best to let your body follow the flow of the bike over a jump.
I have another question. When you looking to land from a jump, something like the OP was doing, do you aim to touch down with your rear wheel or front wheel first?
Or on what kind of jump would you aim to touch down with your front or rear wheel?
Sorry for the nooooooob questions but i would love to learn.
Posted : 13/12/2010 10:34 pm
Pull back and yank if you want massive air.
Posted : 13/12/2010 10:37 pm
 jedi
both together is the best landing
Depends on the jump.
If its a properly maintained dirt jump with kicker and landing you don't need to pull on the bars
the correct speed will see you through - just follow another rider in.
Some of the trail centre style tabletops I've ridden are a bit long to clear just with speed so you often need to generate a bit more air to get to the down slope. Pull on the bars into a bunnyhop style movement works.
...for me that is 🙂
Posted : 13/12/2010 10:47 pm
"It gets confusing, I have read so many threads and tips on learning how to jump. "
Listen to Jedi, end of.
Posted : 13/12/2010 10:48 pm
timpol is right, listen to Jedi
Posted : 13/12/2010 10:52 pm
I'd second what ahwiles is saying about Bolehills, failing that the play track in wincobank is good fun as well. It depends what you want to learn to do. That jump is esentially just a small kicker with a downhill landing. Therefore Jedi is right in that respect that you want to land both wheels together or slightly rear wheel first. If it's a properly built jump (Double or tabletop it doesn't matter) then bumhands is correct in saying that the correct speed and weight distribution will carry you over. In that situation you want to land front wheel first just beyond the top of the landing having followed a smooth arc from the take off to the landing. Your rear wheel should then land where you front wheel did as you ride out the landing. If you get it right then you can pump the landing for increased speed.
Posted : 13/12/2010 11:04 pm
Listen to Jedi I will....
Jedi are you Tony from this thread????
http://www.singletrackworld.com/forum/topic/was-my-skills-course-worth-it
I watched a bunny hop video the other day, it looks like there are skills there which could be really useful in jumping.
Thanks for the input guys.
Posted : 13/12/2010 11:05 pm
Thanks Pete0,
That makes good sense.
OP.. sorry I didn't mean to hijack your post.
Posted : 13/12/2010 11:09 pm
 jedi
slightly front first is next best!
yeah i'm tony 🙂
Posted : 13/12/2010 11:17 pm
I'm no teacher, I'll leave that to Jedi but a bunnyhop unlocks lots of different skills on bikes.
One thing Jedi taught me was that landing rear wheel first is a bad idea, and boy is he right! Did it slightly over a drop on the black at cmwcarn, just before a corner, rear wheel first equals zero steering ability. Made it round but probably stained my pants!
Posted : 13/12/2010 11:26 pm
Always important to remember that jumping and drops are two different activities so have slightly different techniques. On a mountainbike trail you find very few true jumps most are drops or step downs at best, unless you go looking for them 🙂 It also all depends how steep the landing is and what comes after it.
Posted : 13/12/2010 11:37 pm
Listen to Jedi, or even better book a day with him. You will definitely get your money's worth.
Posted : 13/12/2010 11:52 pm
I'd be up for a skills course.
Where are you based Jedi?
Posted : 14/12/2010 12:11 am
 jedi
im in hertfordshire
thanks for your kind words mrgreedy 🙂
Posted : 14/12/2010 12:13 am
I'm in Yorkshire... bit of a drive but could be tempted to make a couple of days out of it. Possibly a couple of mates would be interested too... we have been kicking ideas about for what to do next, maybe a weekend away or whatever and I think this would be a cool idea.
Jedi, email is in my profile. Could you send me your prices? I might be able to make it an Xmas present from the GF!
Posted : 14/12/2010 12:26 am
Moonhead, look here for details of Jedi's courses http://www.ukbikeskills.co.uk 🙂
Posted : 14/12/2010 12:44 am
Bookmarked! TY Keyses2 🙂
Posted : 14/12/2010 12:54 am
no problem 🙂 , he does gift vouchers if the GF needs present ideas ...
Posted : 14/12/2010 12:58 am
Course with Jedi is the way to go!
The basics are push about a strides length from the lip, look forward to your next section.
Posted : 14/12/2010 1:28 am
 Euro
You'll need to consolidate the mental and physical skill sets and extrapolate the boost for maximum effect.
You could always go and ride with others who can jump. Watch what they do and ask for tips - most wont charge for it.
Posted : 14/12/2010 9:37 am
moonhead - you have seen my experience with Tony, Euro is right and thats where Tony's ability to work on the mental side is so important. You could go and learn of others but i found it alot quicker and alot more effective learning it correctly from Tony first time. Dont forget he will also work on every bit of your riding, well worth the money in my book.
Posted : 14/12/2010 9:57 am
you need to make sure your suspension is not too soggy too. i have fun on my xc bike with undersprung forks if i dont remember to wind on the compression damping when trying to jump the thing at the bmx track.
that said its fine if i remember its set softer. i can compensate more i guess. its just alot harder work.
Posted : 14/12/2010 10:16 am
 jedi
moonhead ygm. 🙂
Posted : 14/12/2010 10:46 am
it's full of [s]30yr[/s] 50yr olds falling off, [s]learning[/s] failing to jump
my 8 yr old daughter laughs at me, says its easypeasy
Posted : 14/12/2010 11:33 am
On the suspension note,
I found a full susser really easy to jump badly
Try a fully rigid for learning the technique, I learn't on a trailstar with Z1 with the lockdown to about 25mm of very stiff travel.
Then go back to suspension which in some ways is now harder work, as it feels energy sapping, but equaly seems more rewarding when you get it right as you go for miles!
Practice Practice Practice though, its definately a summer technique as turning up at the dirtjumps to ride in this weather is a sure fire way to not be welcome back in the summer. Take a spade and make some friends.
Posted : 14/12/2010 11:35 am
I broke my hip 'learning to jump'.
My advice is;
a) take someone with you
and/or
b) ensure your mobile phone is charged.
In the absence of both of the above it feels like a long wait until someone comes along and wonders why there's some bloke lying on the ground with their leg at a funny angle.
Posted : 14/12/2010 11:38 am
Fully rigid is easiest to jump yeah, when I tried out bmx again I was amazed at how much momentum the suspension sucks out. It feels scarier though as if you **** up it's a bit harder to recover and roll away from.
 Euro
Is the heels down thing really needed for jumping or is it a ploy to try to get the correct body position? I've never noticed myself doing it and, after doing a simulated jump or two in work just now, I honestly don't think I do do it.
Posted : 14/12/2010 1:03 pm
Wwaswas, did you learn to jump in the Brighton vicinity? I'd like to get better at air (indeed a Jedi skillz course is planned for 2011) but half the challenge is finding beginner safe jumps.
Posted : 14/12/2010 1:26 pm
