srx is a little modified,, when I bought it it would brake into a tank slapper over cats eyes and white lines ,, i thought about a steering damper but went the other way from "normal" i reduced the trail by dropping the front and raising the back thinking there would be less self correcting force so less inclined to wobble
a speed wobble is when the self correcting force is greater than needed to return the wheel to the centre so then it goes past the centre so you then have more correcting etc so it all increases
rear shocks 22mm longer than std front end 12mm lower forks through yokes. rear springs dual rate front end wp fork kit,,
even has data logger on pic 2 you can just see front wheel speed sensor and front and rear suspension pots
i had to take off the hero spikes off the footrests, and slightly change the exhaust as that is a bit solid when it hits
a great little bike
