Is there any boardw...
[Closed] Is there any boardwalk at Gisburn?
[#2203313]
Does it get icy?
Posted : 19/11/2010 10:05 am
Yes there are a couple of sections and they are usually fairly slick in the wet. Cant remember from last year how bad they were in the ice, just keep of the brakes and youll survive!
Posted : 19/11/2010 10:26 am
Never seen them get icy but as stated in the wet they can be lethal, I've bailed once and seen it happen to numerous others. Handily, the ground around them is soft so its usually allright!
Posted : 19/11/2010 10:48 am
Was there last weekend, after all the rain - and early rain on Sunday morning.
Awful stuff.
Wouldn't get me anywhere near it if it was icy.
Posted : 19/11/2010 10:50 am
Was up there on Wednesday, it was wet and didn't seem too slippy as long as you don't brake hard or make any sudden moves - then it is lethal.
Posted : 19/11/2010 11:07 am
I was there not last Sunday but the Sunday before, parts of it were covered in frost, it was fine to ride on
Posted : 19/11/2010 11:09 am
What are you lot on about?
The board walk stuff at Gisburn is absolutely fine in the wet. Plenty of grip, since the wood is rough split.
No problem in frosty weather either if I recall correctly.
Posted : 19/11/2010 11:11 am
agree with glen h very differnt to north face in grizedale ( I came off there and have hated woord ever since) or llandegla scary. Very grippy wood at gisburn
Posted : 19/11/2010 11:48 am
Agree. Much grippier at Gisburn!
Posted : 19/11/2010 6:19 pm
Never had an issue with the wood at Gisburn, it looks grippy as it's rough cut, then again I'm always very cautious on it but might be 'cos I'm a big wuss 😐
Posted : 19/11/2010 7:14 pm
The boardwalk stuff at Gisburn is rough split logs so it has grip, it seems to work quite well although doesn't have much lateral grip, so you still need to be careful.
The log rides at Gisburn use a grip method which was first spotted by SingletrAction, being used at Golspie (I think), then used extensively at Stainburn, then a few SingletrAction people went to Gisburn and did the same for them.
This below, took me about 2 hrs, I had some training tho from the master, Knacker (pictured above, back to camera).
Posted : 19/11/2010 9:40 pm
