Is my light battery...
[Closed] Is my light battery charging??
[#3725993]
Brought my light to work to charge for tonight (chinese job) but forgot the charger
Turns out my laptop charger fits the terminal perfectly - anyone the faintest idea if anything is going in??
Posted : 29/02/2012 2:22 pm
BOOOM
Posted : 29/02/2012 2:24 pm
*puts kettle on battery*
IF the voltages and polarity are correct - theres a good chance that the + pin on the charger side wont be touching the inside of the battery connector.
I presume you've not actually plugged it in?
Posted : 29/02/2012 2:29 pm
Did you read the 'CAUTION'' label thats visible on the back of the charger?
'for use only with InformationTechnology Equipment'
Posted : 29/02/2012 2:31 pm
Plugged in - no smoke or anything, perhaps I should nip down to Maplins 😯
