Hi, as you can see I've got some centre locking hubs,(not sure what that means). I have been given some Hope floating disc's that i would like to fit, these are 6 bolt and the same size disc as fitted already 203mm. I've included a photo of an adapter to do this job, or so I think. Could anybody just confirm that i'll be able to do this using the adapter, or have i missed the point all together and do not need an adapter before i order 2. And would it change the position of the disc to caliper? From what i can see from the back there is a face on the hub to fit a disc to, with 6 threads, which the current disc is fitted up to. Hope someone can explain, I'm confused! Thanks
