How Much Sag Do You...
[Closed] How Much Sag Do You Have?
[#3981328]
Always had coil uturn forks, had little adjustment with regards to sag.....I am soon to be the proud owner of a set of shiny new Fox 36 Floats 😀
I have a Charge Blender as an all rounder rated for forks with 100-120mm travel however in the past I've also run Pikes with 140mm. I ride trails, xc, 4x, and mini DH and it really is a mix there is no dominant type of ridding, trying to decide what travel to set the floats at and how much sag to run!?
140 with 25% sag is effectively 105mm 120 with 15% is 102mm (15%-25% is apparently the recommendation) so seems a bit of a mind field.
My questions are:
How much travel do you run?
For what type(s) of riding?
And how much sag % wise (roughly)?
Also any suggestions?
Posted : 16/05/2012 6:49 pm
How much travel do you run? 100mm
For what type(s) of riding? XC and longer distance
And how much sag % wise (roughly)? 25%
Posted : 16/05/2012 7:07 pm
A lot more after 2 kids
Posted : 16/05/2012 7:18 pm
Ran about 30% on my dual air pikes, coil lyrik now and the coil is giving me 28%, but I feel its over-sprung, so i'm probably going to drop down a coil strength.
Posted : 16/05/2012 7:24 pm
i run 30% on the front(bos devilles) and rear i run 40%(CCDB)
i only have 1 bike and it does everything.Mainly xc/trail
Posted : 16/05/2012 7:38 pm
I'm trying to.figure is it best to have more travel....more sag or less travel less sag?
Posted : 16/05/2012 7:40 pm
XC riding (with a lot of steep stuff)
Giant Anthem, 100mm travel, 25% sag
100-130 u-turn fronts, 25% sag. More pressure in neg chamber to give nice suppleness
Posted : 16/05/2012 7:42 pm
 GW
If you're doing the blender justice go less travel and less sag.
A shorter stiffer fork will pump, jump and turn better with a firm set-up
Posted : 16/05/2012 9:17 pm
So where do you find that much time?
Posted : 16/05/2012 9:21 pm
140mm HT. Trails, XC, Gravity Enduro, just getting into mini DH. 15-20% sag - firmer when it's drier, softer when it's wetter, though it's not something I change frequently. I think hardtails feel weird when the front is too squishy as there's only a couple of inches of steeply ramped up tyre, wheel and frame give at the back.
Posted : 16/05/2012 9:33 pm
I use a quarter whether i'm riding locally or black/red graded trails.
I suggest you do the same and add or decrease depending whether you're bottoming out too often or not at all...
Posted : 16/05/2012 9:35 pm
 jimw
When you reach 50, most things start to sag
Posted : 16/05/2012 10:02 pm
Have Fox RL 32 Float.100mm. Initially had them set at 30% but after a ride out found them to be far too soft. Reduced the sag to 20%, much better.
Posted : 16/05/2012 10:08 pm
