Hope Floating Rotor...
[Closed] Hope Floating Rotors for DH
[#3644589]
yes or no on a set of v2's on a DH bike?
just bling or worth it? they are the same price so thats not a factor
thanks in advance
Lee
Posted : 04/02/2012 11:26 pm
apparently dissipate heat quicker because of the aluminium spider they're mounted on.
I ran them, but can't really tell the difference between those and normal ones
Posted : 04/02/2012 11:27 pm
They make a cool noise as they cool down.
Posted : 04/02/2012 11:43 pm
Just bling IMO. Not even all that light, and bring with them their own interesting issues.
on long alps runs there is a difference, with the heat dissipation but on short stuff not much.
Posted : 04/02/2012 11:45 pm
How can I phrase this without infuriating a Hope fanboy... If you have issues with the heat dissipation even with a big rotor, the solution isn't fancy rotors, it's a brake that can deal with the heat buildup better than Hopes do.
[i]IMO ;)[/i]
Posted : 04/02/2012 11:49 pm
V2's need the moto/v2 rotor (thicker braking surface) I thought that was only floating (or vented) anyway, didn't know there was a Non floating version)
Posted : 05/02/2012 12:57 am
oh looking on crc it lists all the colours of floaters and just disks?????
Posted : 05/02/2012 1:13 am
203mm version and like I say they are the same price? do you think this means the non floating are the vented ones?
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=16365 ]v2 disks[/url]
Posted : 05/02/2012 1:16 am
You can get a one piece rotor, a floating rotor or a vented rotor for the v2. My choice was the floating version. They look good and they give the pads something to grip on. What more does anyone need to know?
What forks and hubs are you running? Some combinations will catch the bobbins on the rotor. My fox 36 with hope EVO pro II work just fine.
Posted : 05/02/2012 8:44 am
what issues are those, northwind? not much point in writing that they have problems, if you don't say what they are.
Posted : 05/02/2012 9:09 am
On my fox forks/CK hub set-up the rivets that hold the floating rotor to the spider would not clear the tiny gap between fork leg and hub.
They really wont dissapate heat better.
Its bling, nice bling, but bling all the same.
On my racing offroad motorcycle the rotors float to take up any movement in the rotor/rim. Not to get rid of heat.
Posted : 05/02/2012 10:29 am
The point of a floating rotor on any vehicle(car,bike,etc) is not to disipate heat faster,but to handle heat without warping. So if you are warping solid rotors then a switch to floaters might help, but if you're boiling fluid or overheating pads then its unlikely to help.
Posted : 05/02/2012 12:36 pm
vinnyeh - Member
Fair dos, I thought they were well covered... The rivets often become loose over time which can reduce braking effectiveness and make a bloomin orrible noise. Also, they don't fit well with some combinations of wheels and forks- Fox 32s don't have much rotor clearance and can come into contact, frinstance.
Posted : 05/02/2012 3:22 pm
If you have issues with the heat dissipation even with a big rotor, the solution isn't fancy rotors, it's [s]a brake that can deal with the heat buildup better than Hopes do.[/s] using your brakes less.
Fixed that for you.
The rivets often become loose over time.
They really don't. Occasionally, perhaps; but not often.
Posted : 05/02/2012 3:58 pm
Three_Fish - Member
I had 2 sets... One did it, was replaced on warranty, the replacement did it, that was replaced on warranty too, I sold them, then they both did it. So that's 4 failures out of 2 rotors 😉 The shop that sold them said, quote, "That's why we've got them discounted- we're not going to sell these any more, they're too much hassle since they all go wrong". YMMV of course.
And yep, use your brakes less but I'm assuming anyone that's trying to fix that software problem with a hardware fix has already given up on that.
Posted : 05/02/2012 4:05 pm
if they're just bling I'll get solid ones then, bikes blingy enough as it is so I'm already going to have to improve vastly this year to stop people laughing at me, I've never warped a rotor so I'll not bother
thanks
Lee
Posted : 05/02/2012 4:19 pm
 duir
Hope floating rotor rivets come loose? Do they? Never heard of that before. My V2 floating rotors on my DH bike are 3 years old and in perfect working order and certainly not loose.
As for the usefulness of the floating bit I am not sure but the reason I went for them was to avoid the revolting rusting of the rotor arms I had on every single set of appalling Avid brakes I had before the v2s arrived.
Posted : 05/02/2012 5:43 pm
I've been using 203 floating rotors on my DH bike for about 4 years and I really rate them. You don't get that horrible warble that you do when normal rotors start to warp (and rotors will get hot enough to warp before your fluid boils and you pads glaze, at least if you're using M6 Ti's), they've stayed true, I've not seen any loose rivets yet. Overall a good experience.
Would only go back to conventional rotors for DH if they were considerably cheaper.
they warp when they're hot, they don't normally stay warped.
Posted : 05/02/2012 8:36 pm
duir - Member
Hope certainly had 😉
Posted : 05/02/2012 8:51 pm
No the vented ones are floaters also and are around 80 quid a pop.
If they are the same price then go for floaters, much better IMO, got hope floaters on both bikes and had no probs in 3 years.
Edit, don't get em from CRC tho, much cheaper else where, shop around.
Posted : 05/02/2012 9:02 pm
can you point me in the right direction please, I'm going to be buying the full v2 setup for my new DH build
ps shipped to Canada{which crc are good at}
Posted : 05/02/2012 11:18 pm
