home dentistry - an...
[Closed] home dentistry - anyone tried it?
[#738858]
Just curious after hearing about some home filling kits, anyone tried these or any other more adventurous proceedures?
Posted : 27/07/2009 12:52 pm
Of all the things to save money on, i suspect dentistry is probably one of the worst.
Posted : 27/07/2009 12:54 pm
 Nick
Aren't those home filling kits basically designed for emergencies? Sort of thing you'd take if you were spending 3 months treking in Nepal or racing to the North Pole or somthing.
Posted : 27/07/2009 12:55 pm
My future Wife's father used pliers on his kids to remove loose teeth.
I can give you his number if you want.... 😯
Damn that wasn't the gorefest i was after, i thought with all the sucsessful bike bodgery the STW lot would of at least attempted a few Dremel aided root canals. 😆
Posted : 27/07/2009 8:46 pm
tooth removal via twine and a door handle ....
Posted : 27/07/2009 8:57 pm
Mmm home dentistry is not a good thing, Mrs C used to work as a dental nurse. Had a patient come in 1 day he didn't want to pay to have a tooth removed, said he could do it himself, a few weeks later she see's him and finds out he tied a weight to it, threw the weight out of the window and broke his JAW!!!.....tooth still in place.
Posted : 27/07/2009 9:03 pm
AARRRRGGGHH!!!!
Posted : 27/07/2009 9:56 pm
im not a rich man but.....if you can afford a bike, you can afford a dentist!
Posted : 27/07/2009 10:01 pm
 Jay
The string and door handle method, reminds me of Tony in men behaving badly doing that. 😆
[url= http://www.veoh.com/group/men-behaving-badly#watch%3Dv18542716r5PxKfS6 ]About 6:50 into the episode[/url]
Posted : 27/07/2009 10:43 pm
We had a chap come into A&E who had tried to smooth off a cracked tooth with a dremel and less than steady hands 😯
Posted : 27/07/2009 10:53 pm
After working in Central Queensland, where dentists are very scarce, I bought some stuff to put on your teeth if you ever got a bad case of tooth ache. It is only a temporary measure, giving enough time to try and find a dentist and a good few hours drive to the dentists surgery. My wife used it once, and it worked.
I also know a bloke back in the UK who had a tooth ache at work, went to the workshop, got a pair of pliers, and you can imagine the rest!
Posted : 27/07/2009 11:08 pm
worked with a guy who used to use superglue to stick crowns back on and fillings back in!! said he had a lab coat and therefore qualified!
Posted : 27/07/2009 11:30 pm
I've tried the temporary crown cement you can buy in Boots before. Dentist said it actually made a permanent reattachment harder and it only laste 2 days in any case before it fell off again!
Posted : 27/07/2009 11:32 pm
DIY dentistry....kind of in the same league as DIY circumcision, i.e. its a no brainer!
Posted : 28/07/2009 10:59 am
I had a dentist remove a wisdom tooth and he hurt me so much I wouldnt go back, took my own stitches out, this might have proved quite addictive as I have in the past tidied up a filling with some wet and dry paper as it used to snag food, much better now.
I DRAW THE LINE HERE, I WOULD NOT DO MY OWN FILLING AND DRILLING!!!
Posted : 28/07/2009 11:08 am
Agree with Tinsy. A bit of filing and wet&dry on jagged bits OK, nothing more.
Posted : 28/07/2009 11:10 am
DIY dentistry....kind of in the same league as DIY trepanning, i.e. its a no brainer!
Posted : 28/07/2009 11:15 am
 D0NK
Guessing samurai wont be along in a minute with a witty comment.
My mate used superglue to stick a false tooth back in, his whole face swelled up, he looked like a chimp.
Posted : 28/07/2009 1:06 pm
My brother filed his front tooth down after he'd chipped it.
Posted : 28/07/2009 1:40 pm
