Viewing 3 posts - 1 through 3 (of 3 total)
  • Help with hope brake mount.
  • NedFlanders
    Help needed with which mount I need for the following.
    Post mount forks, old 4 pot mono IS mount trying to run a 180mm rotor I tried HBSM20H one but it only just met the rotor.
    Any advice in what bracket I need
    Thanks
    orangeboy
    What forks do you have. Not all post mounts are the same.
    Big forks 36s etc often use a different spacing
    bigG
    I think you’ll find your answer in this thread.
The topic ‘Help with hope brake mount.’ is closed to new replies.
