i blew my rear mech up last weak as it was a little to short when my rear shock was fully compressed,
i had crc post me a new rear mech and a pc991 chain (as before ) as i had binned the links so couldn’t
get the chain length correct,
i fitted the new rear mech today and the chain and let the shocks air out ,strapped the wheel in against the seat post and cut the chain etc, fitted a new cable, set the tension, stuck it in top and bottom sprockets set
the limit screws, job done,
bit of background, the blackspire front chain ring has only had two rides, max 40 miles. and is in no way showing any burrs or signs of wear or elongation of the tooth form.
the chain is new as stated, the rear mech is new straight etc, the hanger is not bent, the chain line is fine
as this is not changed,
the rear cassette is 6 months old, it’s done max 15 rides out all at woburn i think, a total of around 300 miles ?
is this my problem ?, it hardly shows any wear, the chain seems to slip over the cassette ..
help please
