help needed with bb...
[Closed] help needed with bb7's
[#2346211]
after a couple of months commuting and a lot of snow riding i thought i'd give my brakes some TLC but i've moved the outboard ajduster in with the pads removed "idiot". I'd forgot thats a stupid thing to do with bb7's,anyhows can you get the cam thingy back in without stripping it ?
Posted : 07/01/2011 3:18 pm
There's a little circlip in there to stop the pad carrier going out too far. Once it's gone past its groove it's almost impossible to get it back in.
What I did when servicing my BB7 callipers was remove the circlip and replace it with an O-ring. When lightly greased with high melting point grease it slides back in easily and if it doesn't try again with a new O-ring.
The pad carrier can't fall out in use because it doesn't come out far enough - the brake pads make sure of that.
Posted : 07/01/2011 7:23 pm
thanks for the reply,will the circlip go back on if you strip that side of the caliper,i know they arn't supposed to need servicing but there is a service manual on sram website.
Posted : 07/01/2011 7:41 pm
