Have a Royce sq taper bb but need to know wether correct length for my 2010 Helius CC, anyone know the correct length required?
Bike Forum
Helius help
Posted 1 year ago #
It will depend more on your chainset. What you using?
Posted 1 year ago # -
My helius am had a 73mm bb
middleburn chainset RS7
From middleburns web:
Having the right BB length is crucial to having gears that work as well as intended.Middleburn cranks run a 50mm chain line.
For a standard MTB setup a 113mm axle is needed for ISIS or square taper.
However, there are far too many variables to always be able to predict what bottom bracket you need. BB-mount ("E-type") front derailleur and chain devices can throw a stick in the works, as can a lot of oddly designed frames.
If in doubt have your local bike shop fit your cranks.
So 73/113??? If you already have the bb, why not try it and see?
Thanks
Posted 1 year ago #
Topic Closed
