Helicopter tape que...
[Closed] Helicopter tape question
[#1078025]
Hi all
I've recently had my Orange 5 refinished (it looks amazing, like a new bike! I would strongly suggest anyone that is considering getting this done to go for it! You will not be dissapointed!) and I am looking to protect the finish on it (this time).
I've been told to use Helicopter tape to cover the exposed areas but I don'#t know where to get any.
My questions are:
Where can I buy Helicopter tape?
How much will I need to protect the frame from general ware?
Any tips on fitting/installing...whatever you call it?
Many thanks in advance for your advice.
Evers 😀
Posted : 26/11/2009 11:29 pm
Ebay - there is a seller called bike tape / bike tart who sells small rolls from which you can cut to shape. Good product, good price and quick service. Search for helicopter tape.
Posted : 26/11/2009 11:42 pm
Just Riding Along. Proper stuff, good price, great service.
Simples.
Posted : 27/11/2009 12:07 am
Halfords sell something very similar, made by Foliatec i think, and it's designed to go on front bumpers or bonnets to protect from stonechips...
Posted : 27/11/2009 12:17 am
Bike Tart +1 8)
Posted : 27/11/2009 1:43 am
HeliTape contact duanebw(at)gmail.com
Posted : 27/11/2009 2:08 pm
Everlong
I covered my new O5 with it earlier this year, the flat sections (like the sides of the swing arm) are fine, however the underside of the downtube is a bit of a bugger. The weld seam down the middle means you can't get it perfectly flat so you get gaps at the end which list dirt and sh*t underneath. It still stops stone chips but looks after a while it looks a bit manky.
Also, avoid putting it where you're likely to clamp it in a stand, if you have one, because it can pull the tape off if you try and rotate it with opening the clamp properly. I used proper 3M stuff on my old Turner and it's much much better (the glue is totally different and it's thinner and more flexible). With hindsight I wish I'd got the pukka stuff for the Orange.
Posted : 27/11/2009 2:17 pm
Brilliant, thanks to all who replied. I'll have a look at the above and get sorted from there.
Thanks again. 😀
Posted : 29/11/2009 2:12 am
Done the whole of my newly re-sprayed Orange 5
I used onlinebikes
They sell tape in large sheets and ideal for the
swing arm Its around £ 6 quid a sheet
Posted : 29/11/2009 6:50 am
another tip, get a hairdryer or hot air gun and warm it up before putting it on, the tape goes a lot more flexible which allows you to mould it around corners and seams that bit better.
Posted : 29/11/2009 9:52 am
+1 for hairdryer method. Warm the frame, apply tape, then heat it again whilst moulding
Posted : 29/11/2009 9:56 am
yes and clean the surface before sticking!
Posted : 29/11/2009 1:49 pm
Excellent, thanks again all. I really appreciate your time.
Posted : 01/12/2009 11:28 pm
