Is it worth paying extra?
Chat Forum
HDMI cables. Worth spending a bit extra?
Posted 1 year ago #
No.
Posted 1 year ago # -
Yes. Make sure you get the directional ones as well.
not at all, save your money
no, not at all.
£1.99 ones we sell are just as good as £49.99 ones we sell.Posted 1 year ago # -
If it's for a long run then probably worth spending a little, and i mean little bit more, other than that, as above, no.
yeh, IMO
wouldn't buy one for a quid - wouldn't go over a few quid either thoughPosted 1 year ago # -
I have monster carbon fibre titanium coated purple anodized hdmi cables and they give me 50% extra pixels on my tv!
Depends what you're doing with it. If you're threading it somewhere where it's hard to get at then it's worth paying a couple of quid for something reasonably robust. Otherwise the 10p freebie that came with your DVD player is fine.
Ok, its for a PS3 so next question - Buy the Sony PS3 one for £18. Or an equivalent known brand one for about the same money? Also, bloke in office says get a 10.2 one?
over a distance less than 10m it makes no differance......trust me.
i sell this stuff for a living.Posted 1 year ago # -
If you're running Blu Ray to a HD Projector then yes. I noticed a massive difference changed to Chord cables.
ton - Member
an honest salesman!
Just get a cheap one - no need to spend £18 unless you need a massively long one.
I use cheapo/freebie ones for short runs. >5m, I went with something (still quite cheap) from ukhdmi.com. All looks tickety boo on a 10ft wide projection screen using a PS3 as source.
In my heady days of being "into" hi-fi, I listened to different cables and there IS a difference. Different doesn't mean better though and an expensive cable may sound/look naff to you.
Maybe A/V cables is different again, but my advice is if you can try before you buy, do so. Hopefully you'll notice no difference
Posted 1 year ago #
mf.........perfect
The only person in the world to then.
Makes no odds what so ever as it's digital, unless like Ton says over a certain length. I had the figure of 10' in my head but I'll trust Ton.
Stilltortoise hifi cables are different again. Used to sell HDMI leads for consoles when I worked in games shop, no difference at all. Always get someone who recons they can tell but it's BS
Cables = Bollocks.
And I am really into music and hi fi
Just get this one and you're done.
...literally.Posted 1 year ago # -
I thought HDMI was all digital, so I dont see how it can be.
If the digital signal gets to the other end of the cable, I dont see how one can be better than another.
In the analogue world, yes perhaps, but not the digital.
digital only might be different to analogue ?
I seriously do not believe anyone could tell in a blind test, not even with a test card screen, never mind when in real-life use.
Fair enough, but I still think it's best to try for yourself. If you think you can see/hear a difference and it makes you feel fuzzy and warm because you bought the fancy cables, then that must be a good thing...
...a bit like most of the mountain bike kit we "discuss" on here
Further reading...
http://www.audioholics.com/education/cables/long-hdmi-cable-bench-tests/evaluation-conclusion
summary snippets...
# At lengths less than 4 meters you can just about use silly string (OK, not really) and get HDMI to pass at any current resolution. At less than 3 meters you'll even extend that to 12-bit color and possibly the next crazy idea HDMI Licensing decides to throw at consumers. Don't spend a lot on these cables and if you want to save money you won't let anyone at a big box store talk you into buying from them.# At long lengths (over 10 meters) you really need to pay attention to the manufacturer if you don't want to risk running into potential problems with 1080p and future formats such as Deep Color. With that said, just about any cable at or under 10 meters will pass 720p/1080i and nearly everyone will pass 1080p at 8-bit color as well.
Jamie - Member
Just get this one and you're done....literally.
I dunno - you get free delivery.Posted 1 year ago # -
The only person in the world to then.Makes no odds what so ever as it's digital, unless like Ton says over a certain length. I had the figure of 10' in my head but I'll trust Ton.
Just because a cable is carrying a digital signal doesn't mean it isn't susceptible to rf interference, crosstalk etc.
Also, I suspect that most "Blu Ray to a HD Projector" cable runs are "over a certain length".Posted 1 year ago # -
makes no difference so get cheap but whatever floats your boat if you want to spend a load of money to experience the joys of the placebo affect dont let us stop you
Well, and noting the wink, not really. Binary is on/off. It either works or it doesn't. A bike component can not be judged in such 'ahem' binary terms, so there can be more room for conjecture on quality, perceived or otherwise..
It's minimal so doesn't up.
Why would they, that surely is do purely down the individual set up.
fisha - Member
I thought HDMI was all digital, so I dont see how it can be.If the digital signal gets to the other end of the cable, I dont see how one can be better than another.
Here's a quote for you: "The right amplitude at the wrong time is the wrong amplitude"
Now I'm not in anyway suggesting that the expensive AV cable business isn't 99% snake oil, but just because a signal is digital, doesn't mean it's always perfect.
Posted 1 year ago #
the fact that the signal is digital is not a guarantee that cables make no difference - but the hdmi spec is rigid and robust enough to ensure that there is little, if any, difference between hdmi cables.
Posted 1 year ago #
Topic Closed
