Hardtail with 160mm...
[Closed] Hardtail with 160mm forks...........what is there??
[#1466965]
Hello can people show and tell on their hardtails with 160mm forks, ideally something that still works when the forks are dropped to 130mm for climbing or singletrack.Ideally builds that are less than 30lbs, cheers
Posted : 31/03/2010 9:25 pm
A friend has an 08 chameleon for sale which will handle forks that big...
Posted : 31/03/2010 9:36 pm
What do you intend to do with a sub 30lb 160mm hardtail?
Surely the sort of riding you want a light bike for, you don't want a massive fork?
Posted : 31/03/2010 9:39 pm
fair comment, it is for my nephew, he wants big travel and reasonable weoght. I think 32/34 lbs would be about right.
Posted : 31/03/2010 9:49 pm
DB Alpine climbs and descends schweetly with 160mm forks.
Posted : 31/03/2010 9:51 pm
 rs
you can do pretty much most stuff with a 30lb hardatil, my bike is more than capable of most things and with some lighter tires could be under 30lbs. Sitting about 32lbs with 2.5 tires just now.
new picture
Yea, I agree you can do whatever you want on a 30lb hardtail. My point was more that to get a big-forked hardtail to that kind of weight you will need to use parts which aren't tough enough to take the kind of abuse you would want to dish out on a 160mm bike.
For example, your bike could be sub 30 with light tyres - which would pinch flat whenever you tried to send it. So why not just use say a 130mm fork on that sort of bike?
Ultimately I'm just discussing it for the sake of it - obviously people can ride whatever they want, its all bikes!
Posted : 31/03/2010 10:02 pm
as forks get lighter, parts are lighter and more reliable, so 30lbs should be reasonable
Posted : 31/03/2010 10:06 pm
 lock
im constantley lusting after a big travel hardtail,i just need to do it and get it out of my system
Posted : 31/03/2010 10:08 pm
 rs
Well I could drop a couple of pounds with the fork too, its just a domain which is about 6.5lbs. wheels are Mavic DeeTracks so not particularly light, hone cranks, sunline bars, thomson stem, its all solid stuff. A well specced 30lb 160mm hardtail would handle all but the biggest drops.
Posted : 31/03/2010 10:10 pm
I have one of these as well
and the frame is about to be put up for sale if anybody is interested?
this weighs 30.5lbs BTW
Posted : 31/03/2010 10:15 pm
 rs
Is that allowed? an alpine is for life, not just for christmas 😀
Posted : 31/03/2010 10:16 pm
Purple is bestest. 8)
Posted : 31/03/2010 10:20 pm
I know, sorry 😥
but it just doesn't fit right.
It does go DH very, very well though, that much I will say
Posted : 31/03/2010 10:22 pm
 br
Ok, so they are 150mm forks..., but less than 30lb.
And when plugged into my 456Ti, and an XTR build but same wheels and 2.4's, below 28lbs with pedals/guards etc
Posted : 31/03/2010 10:28 pm
 ash
probably about 32-33lb but still climbs (and of course descends) fantastically
Posted : 31/03/2010 10:32 pm
It was all going so well with all the lovely Alpines... then someone HAD to post an On One...
:mrgreen:
Posted : 31/03/2010 10:38 pm
FWIW, kenneth's 160mm hardtail weighs around 37lbs (after it was lightened). which is probably why he can't fully grasp that other people might be able to get their bikes anywhere near below 30.
Posted : 31/03/2010 10:41 pm
I do fancy one of those, but budget might force me to a Blue Pig. Or even the shame of a 456...
Posted : 31/03/2010 10:43 pm
 mboy
Chucky
What size is the frame, and how much are you after?
Posted : 31/03/2010 10:45 pm
Stevo, if I had room in me bag, I'd bring it over from Edinburgh in August for you to try!
Posted : 31/03/2010 10:49 pm
p29 onwards in the new issue of Wideopen might give some ideas...
http://wideopenmag.co.uk/news/5316/wideopenmag-issue-12-is-here
BFe, Blue Pig and Alpitude ... all fit the bill in their own ways hicksville.
Posted : 01/04/2010 12:19 am
It's a 15.5"/21"
£195 OVNO posted.
only 9 months old and is in very good nick, hardly marked. (was ridden by a 44 year old bloke, who should know better).
emails in profile if you are interested.
Posted : 01/04/2010 6:30 am
Transition Trans Am?
Posted : 01/04/2010 8:41 am
I had the same thing as Chucky with my Alpine. I had the 15.5" / 22" and downhill it just screamed. Was pretty good on techy stuff but somehow just didn't fit right for all-round duties. Shame cause the stuff is was good at it was [i]really good[/i] at!
Posted : 01/04/2010 8:48 am
 hora
I'd run a all day hardtail with 140. I ran my 456 with Lyriks last weekend and TBH I hated it. Straight line it felt good- turned- it felt awful. Thinking back I also remember bailing on some singletrack and just missing a tress on the North Downs a couple of months ago because it felt washed out at 160mm!
Posted : 01/04/2010 8:50 am
Chucky/Coyote, Mk2 Alpines have revised sizing of 16/22.25 and 18/23.25.
Posted : 01/04/2010 9:47 am
Chucky/Coyote - how tall are you guys as might be interested in chuckys alpine. My small PA is a touch to long in the top tube, but concerned 21in might be slightly to short!
Posted : 01/04/2010 9:59 am
i'm 5ft 4"
Posted : 01/04/2010 10:05 am
hmm, 5.9 here - suspect it might be abit small!
Posted : 01/04/2010 10:13 am
5" 9 1/2" so on the cusp between the two sizes really.
I normally ride a 16" Coyote Dual which fits perfectly.
mike at dialledbikes. Everything was going well today. Last day before the long weekend. Just had a meeting cancelled this afternoon which means I can wind down nicely and then you say that. Great. Now turmoil fills my mind. One of the best bikes I ever rode that was [i]ever-so-slightly[/i] too small is now [i]ever-so-slightly[/i] bigger. Looks like the full suss I was planning later this year may be put back again...
Posted : 01/04/2010 10:18 am
I had an alpine and it was a downhill weapon with 150mm 66's. I had a 17/22 and Im 6 foot 2. Felt spot on for dh, a bit short for xc stuff though.
I think you'd struggle to get it under 30lbs though, you'd want a full selection of dh parts on it, and you cant really go for light weight wheels either. Thats if you want to ride dh on it (assuming you do with 160mm forks, pointless having them otherwise)
Posted : 01/04/2010 10:20 am
 GW
still think alpines ride nicest with a 100mm fork 😕
Posted : 01/04/2010 10:39 am
Surely if you want a 4” fork then a PA makes more sense than an Alpine though?
Posted : 01/04/2010 10:45 am
Did you sell the Bullitt yet? You bringing that or the 5-spot this time?
Posted : 01/04/2010 10:52 am
Cotic Bfe here. Complete monster loon bike with Lyrics on, bit more all round with Pikes. Surprisingly OK uphill, despite being technically a size too small and with a really dinky stem. about 31lbs with the Lyrics, 29 ish with the Pikes. (assuming single ply 2.3 tyres). Travel adjust forks are a godsend if you want to ride all day on it as well as rag it DH.
Posted : 01/04/2010 10:54 am
if you can cope with 150mm rather than 160, a revelation is only 200g heavier than a SID, so i'm sure a light build would be possible, just swap the wheels for gnarlier stuff?
Posted : 01/04/2010 10:57 am
 GW
Why's that then Cookeaa?
Posted : 01/04/2010 10:59 am
JonEdwards: Good effort on that rock drop! Way more gnarly than it looks in the photo!
Posted : 01/04/2010 11:06 am
as i said it is for my nephew 19 yrs old and off for the summer to the alps, spending the summer out thereand only wants to take one bike which will cover going up and down and be reliable. He is 6ft and 14stone so needs to be robust but he is worried about the long climbs so wants to keep weight down but still sturdy, he will use 160mm travel on the downs and adjust for the climbs
Alpine is a great choice, as if the befe but anything else out there?
Posted : 01/04/2010 11:56 am
http://www.genesisbikes.co.uk/bikes/mountain/alpitude/alpitude/overview/
would be happy with a 160 on the front.
Posted : 01/04/2010 11:59 am
Summer. Alps.
The word "chairlift" comes to mind when it comes to getting up the hill... Even if he sets off with the best intentions to pedal everywhere, I guarantee he'll be corrupted before too long.
Posted : 01/04/2010 12:14 pm
lol Mr Edwards, it is based on his idea to save cash, after working all winter he wants to make his cash last he is taking the dirtbag approach to this excursion.
Posted : 01/04/2010 12:16 pm
Evil Sovereign, On-one summer Season, On-one 456 Carbon should all be added to the list.
As for keeping the weight below 30lb, well with Air Forks (Lyriks or Floats), Hope wheels with Flow rims, and sensible choice of drivechain (ie: not raceface) it shouldn't be that hard.
Only thing I would also definitely recommend is a Thomson post as you are going to end up with a fair bit sticking out, and they don't bend.
Posted : 01/04/2010 12:17 pm
