Grrr. Seized and n...
[Closed] Grrr. Seized and now rounded locking.
 DT78
[#1895978]
Any tips, bloody thing just wouldn't move, bit more grunt and the tool has rounded the teeth off the lockring.
Suggestions?
CK SS hub so hope it's not buggered.
Posted : 15/08/2010 12:12 pm
 DT78
No one got any tips?
Looks like I'm stuck with 18t cog then....
Posted : 15/08/2010 12:53 pm
Saw a notch in it to gain purchase with an expendable screwdrive. Then, using screw drive in a chisel like manner hit it with hammer to drive the lockring round?
Worked to get Cheiftain bb cups out of a frame after a similar incident.
Posted : 15/08/2010 12:58 pm
 tron
Use a cheaper tool next time, so the tool lets go before the lockring does? 😆
You'll not knock it off with a hammer and chisel if the proper tool wouldn't shift it.
I'd be looking to find a garage or engineering firm who could weld a cheap 1/2" drive socket to the lockring and remove it that way.
Posted : 15/08/2010 12:59 pm
Biggest Stilson wrench you can find.
Obvious but make sure you're turning it the right way.
Posted : 15/08/2010 1:04 pm
have you already used plusgas or something ?
(adds: it will strip out all your grease though)
Posted : 15/08/2010 1:13 pm
I had one really stuck once, it was one a wheel I hadn't used for a few years and it really really wouldn't budge. With careful use of a rotating cutting disc on a dremmel I managed to remove the lockring without damaging the freehub. I cut through it as far as I dared and then it was fairly easy to bend/snap the lockring inwards. It was a cheap Shimano hub so I wasn't too bothered about damaging it, but it survived intact.
Posted : 15/08/2010 4:53 pm
DT78 - Member
Suggestions?
If this is a traditional track/fixed type hub - then the lockring will be a left handed thread. Not familier with the CK SS hub so maybe different?
Ah just looked on the CK website - it's cassette type lockring. If completely rounded then I would get the Dremel out.
Posted : 15/08/2010 5:00 pm
File the lockring down flat until it reaches the freehub body,The Ring should come off and then just un-wind the threaded part that is left in the body,With no tension on the threads it should unscrew easily.
Posted : 15/08/2010 5:03 pm
