GPX File Editing
[Closed] GPX File Editing
[#3741885]
I want to edit a GPX file to reduce the density of the data points, eg reduce by 50% or 75% for example. I know I can edit the file by hand via a text editor but I wondered if there was a utility for MAC as diing it manually is very tedious, free is good !
I've done a little research online (eg ADZE) but wondered if anyone here had a better solution.
Posted : 05/03/2012 1:20 pm
I've never tried it but in bikehike.co.uk there's an option to reduce the number of track points which might do the trick but it's to a set number of points rather than a percentage afaik.
Posted : 05/03/2012 1:24 pm
I think that GPSBabel can do this.
There is a simplify option which should do what you want (although there are probably other options if not)
http://www.gpsbabel.org/htmldoc-1.3.6/filter_simplify.html
Posted : 05/03/2012 1:29 pm
I'd look at GPSBabel. Works on pretty much any platform, with pretty much any GPS input file (GPX, KML, etc. for routes, tracks, waypoints etc.)
edit: must type faster 😉
 Pook
upload to bikehike then fill yer boots.
Posted : 05/03/2012 1:32 pm
There may be easier ways but I open the route with gpsmarengo and replot in a new tab of gpsmarengo with desired number of trackpoints then use gpsbabel to load back to my garmin edge hth
Posted : 05/03/2012 1:40 pm
Thanks, the above looks good and I hadn't come across those programmes - I'll try then out
Posted : 05/03/2012 1:51 pm
Or Garmin BaseCamp can do this. You can download it for free, there is a Mac version.
Posted : 05/03/2012 2:59 pm
Bascamp - I could not find the option to save a reduced track file size, only for device download of routes
GPSBabel - I thin the simplify feature has been removed, linked documentation page says its an obsolete feature and I couldn't find anything similar in the application
bikehike is the winner, it tells you how many track points you've got and you can define a smaller number for file output (download)
Thanks again everyone - FYI I wanted this so I can combine tracks files to create trail maps for myself as I ride different trails on different rides.
Posted : 05/03/2012 7:47 pm
Which version of GPSBabel are you using?
I've got v0.2.22.0, and the simplify function is there. Click on the Filter button and simplify is halfway down the pop-up.
Posted : 05/03/2012 8:21 pm
FYI next time.
Basecamp - right click on track -> advanced -> filter -> points.
Posted : 05/03/2012 8:26 pm
