anyone got a postcode or directions to this area. how long is the red route currently and is it any good?
Bike Forum
gisburn forest
Posted 2 years ago #
you wana try the black route
Posted 2 years ago # -
BD23 4SQ park at the pub then go in after the ride
its got a bike wash etc. good food n drink
whats the length/ time of each route approximatley?
erm if your doing the old routes i think the red was 12km and it recommends 2-3hrs but it can be done alot quicker but its more fun if you just nip off down the new bits and see where they go
the big berms are on the black route near the slab at the top you dont need to be a pro to do them either my mate did them on a cx bike! look on google for the routesheres on of here a while ago
this ones more deitailed
hope it helps
tom
the pub is at the petrol pump sign on the first map then you just ride up the fire road to the red route
Ive been up there and done the red route recently, tbh compared to dalby forest gisburn red route is really short, well seemed it to me but theres alot better technical routes at gisburn, ive been told if you do the red route up until it gives you a bit of a decision to go onto the black by going downhill off the red, its alot better, but its improved since i last went
the firstmap is the "new" redroute at the top endof it you can fork off onto the black route whichyou should do... and then i joins upto the red again
taka - Member
Tom, thats a pint glass
ah, i just stuck to the red all the way because it was my first time since the new construction, wasent sure if the black would rejoin or not lol ;p
lol are you going up on the 16th of jan for that kona demo thing?
black sections are the best bits imo.
Here's the pub. You couldn't hope for a warmer welcome and they've started selling Hope components and Kona clothing.
http://www.dogandpartridgetosside.co.uk/
There's a map linked in to their site.
Saw your van there yesterday Ed. Didn't see you hacking those trees into logs though. They are massive!!!
we went on friday and its ok for a xc route or nite ride but well boreing
Second the pub comments from Ed-O.
Worth using it as a base and buying lunch / a pint etc...They don't mind if you're covered in mud and soaking wet either.
Eh Ed!
You seem to be in a minority there matey. Where do you normally ride that's so exciting?
Canal Paths?
Miaow
gregs891 - Member
Either got lost or trolling
How was todays dig Jon? Have you finished it yet?
Nah, left a bit for the rest of you to do. Got quite a lot done since Thursday, got the S bend before the trees all in and the bulk of a little bridge over the ditch. Coming along nicely. Trouble is the next dig isn't until the 13th so things will slow down a bit now.
Nigel P has plans for even more fiendish log rides a bit further down though so I can see things expanding.
Rather nice little video here of the digging and riding.
The one that you're building looks quite fiendish enough for me. Don't have a clue how to do the drop off, on a corner from the top tree to the bottom one. Might chicken out of that bit.
Had my first trip up here today.Parked up at the pub,which by the way is very good.Fine chilli and chips and a decent pint.
Going from the pub you end up doing two loops,the first i found to be very rough,i put this down to the weather.I'm sure the rain has washed away some of the smaller stuff.
The second loop was much better and the fast tight slalom type rutty sections were very good.
I also stummbled across a very good natural singletrack section....if you go up the climb were the in/out signs give you an option,turn left at the top,then go straight on past the right turn to go onto the red trail and down the fire road.About 300 yards past this is a turn left into the wood...wow very good indeed !
A good new bit of trail you trail building Hobbits have put in since I was there on Thursday.
ChatsworthMusters - I was working up there yesterday and today, hence the van at the D&P. Having a pint at the end of both days as well - well you do have to have a debrief
Coolhandluke - you knows it
theres a lot of work gone in to it but is just do'nt give u a buz jus boring stumpyjon we ride in the peaks
And in English?
If you're going to slag off peoples' hard work you could at least bother to spell it properly. I wonder if you even rode it all.
FWIW I think there are some really good bits and some not so good bits - the volunteer sections and the two black bits are great fun but quite a bit of the rest is so-so imo.
Been sampling the local produce perhaps?
i am not slagging off peoples hard work, they must have worked very hard but all i am saying is that its a xc route and is is this spelling any betterrrrrrrrrrrr
Yes it's an XC route, what were you expecting?
for it to give you a buzz
Did you not get a buzz out of the silly huge berms on that gully bit? One of the most fun sections of a trail centre that I've ridden. The slab and the little section of berms/jumps after it is pretty fun too, as is the optional black bit just before it that goes down to the big rocky berm thing.
A lot of the rest of it (apart from the volunteer bit) I wasn't too thrilled by but it was ok.
yeah the big berms were good some bits before that as well, it mite just be me,there's a lot have work gone into it tho,
Still not sure what you were expecting though. I've not ridden many trail centres but I'd say a lot of it is on a par with Afan or Cwmcarn except for the sustained descents, that said there is still a lot of pedealling at those two centres to get to the descents. It's definitely better than Llandegla. There is good riding in the Peaks but you've still got to connect it up which surely isn't that thrilling.
Topic Closed
