Lets ask a simple question njee20. When you fall in a crash or just simply drop your bike what are the first two contact points to connect to the floor… pedal and bars on a road bike.
I have had one bike crash so far with my Vectors which was sprinting on the road and hitting ice. Snapped the pedal in half and Garmin said they where concerned by the possible effects on the internal strain gauges.
First two contact points depend on the crash, in order for it to be the pedal you must have had the bike slide out, in which case I’d certainly expect superficial damage, but not a more comprehensive failure of the pedal. Clearly you’ve had it happen with a Vector, but I still maintain that more people will have (and are more likely to) damaged cranks irreparably than pedals.
I’d sure as **** not expect a pedal to snap in half if you simply drop your bike.
