Interested in this for my christmas list if I can save up enough spending money….
I’ve seen a couple of reviews online from a while ago but wondering if anyone on here has used one and how you rate it?
the main thing i’d hope to use it for is to get a pre-planned route and just follow directions on the unit…
I’ve not ever used any GPS thing, can you plot out a route at home and load it on so it tells you where to go? does it work out the waypoints where to turn or do you manually have to put them in?
what about if you get to a junction with say a couple of bridleways quite close to each other- do you often take the wrong one initially by mistake? not sure how accurrate the things are…
is the 1:50 OSmap readable and useful? do you also get a ‘normal’ road map for road riding as standard?
I thank you in advance- Cheers 🙂
