FS suggestions for ...
[Closed] FS suggestions for 6ft2 16stone
[#613127]
Hi, I am 6ft2 and 16stone so not small. I am looking at suggestions for my first FS bike. Currently do Xc and singletrack which I have a Kona hardtail for but I want to try some of the welsh trail centres.
Dont really want to spend more than 1500. Was looking at the Cannondale Prophet 2 and Trek EX7 but not sure what else is worth looking at. Ideally easy to set up and maintain. I am very technical just very lazy 🙂
Alex
Posted : 07/06/2009 9:01 pm
From tomorrow (monday) we are offering our Chumba XCL frame's at £799 reduced from £1399 for a limited period only. With some choice parts i reckon you could build up a bike for your budget. The XCL has 5" travel pretty light but is built to take some abuse, will easily work with someone a bit larger than normal 😉
Posted : 07/06/2009 9:11 pm
I'm your height and weigh 95kg ish. I'm riding a coiler using a 5th Element shock and 600lb spring so it's not hard to get it sorted. So far (about 7 months) the only thing to go wrong was the front shifter when I mashed it.
Posted : 07/06/2009 9:20 pm
I'm 6ft3, 16 stone and ride a Specialized Stumpjumper.
It can handle the easy trails on Vancouver's North Shore (2 feet is a huck for me) and xc's well.
Just pump in more air into the Fox fork and shock and it's all good.
Posted : 07/06/2009 10:32 pm
Si, your speed at replying with offering your imported frames is improving ;o)
Posted : 07/06/2009 10:33 pm
look out for a second hand orange five? best purchase i've made, i'm 6'5" and 110kg, i have total confidence in this bike.
Posted : 08/06/2009 7:52 am
For your budget the Cannondale Prophet sounds like an excellent choice.
Nice tough spec and simple single pivot.
Posted : 08/06/2009 9:04 am
Prophet or maybe a 5 if you have the cash.
(same height & weight with a Prophet here)
Posted : 08/06/2009 1:02 pm
Z1ppy what size did you go for? I am not sure on m/l I currently ride a 19" Kona.
Alex
Posted : 08/06/2009 8:04 pm
6ft 2 15st, fuel ex8, can't recommend it enough
Posted : 08/06/2009 8:13 pm
I went for a large, had sat on several medium's and found them way too short, even when just 'sat' on them. It is seems quite long but I prefer that with this bike.
(I have a 18" inbred, a 17" marin full-susser & a C'dale gemini 19")
Posted : 09/06/2009 2:01 pm
 igm
Orange Five here at a similar weight (if a couple of inches shorter).
It's reliable and rides a bit like a bike
Posted : 09/06/2009 2:21 pm
