Your problem is that your seat will now pivot under its own mass, this will load the front bolts in bending and possibly much more in tension than designed, as they're normally designed to be loaded in sheer (seat is now pivoting about an external point away from the bolt, like the front of the runner) which could well vastly reduce the strength of the bolt and/or pull the other side through the support metal in a peeling motion.
Imagine holding a bolt between your oustretched fingers, grab the bolt near your fingers and try to pull it through your fingers in the same plane as your fingers - fairly easy to resist. Now grab the top of the bolt and attempt to bend it over and pull it out like a claw hammer does with a nail - which is easier to hold on to? Once the seat is free to move, the various assumptions made in the safety checks are invalid as the body is free to move sideways and could rotate sharply if only one bolt fails.
I'd not be driving with you. Doubt it would cause death necessarily, but it wouldn't help in an accident, and probably would make injuries more severe.
