freewheel on a fixe...
[Closed] freewheel on a fixed hub bad idea?
[#3721264]
hey all
i can get hold of one of these
[url= http://farm1.staticflickr.com/186/382682086_88d11f8234.jp g" target="_blank">http://farm1.staticflickr.com/186/382682086_88d11f8234.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/fastboy/382682086/ ]phil wood kiss off disc-fixed[/url] by [url= http://www.flickr.com/people/fastboy/ ]fast boy[/url], on Flickr
dont want to run it fixed tho...thought about putting a freewheel on it bad idea??
cheers
Posted : 28/02/2012 12:31 am
if it's a wood kiss off disc it'll take a freewheel just like this
[img] ?psid=1[/img]
Posted : 28/02/2012 12:47 am
i think so...basically an associate is selling a phil woods 135mm disc fixed hub(most pointless combo im the world if u ask me)and its great hub just dont want to run it fixed.so was curious if it would be ok with a free wheel,probably would run a white I freewheel too
Posted : 28/02/2012 12:50 am
it'll be fine
Posted : 28/02/2012 12:51 am
It's just a hub, the threads are the same.
Posted : 28/02/2012 10:32 am
 Keef
wot they sed.
Posted : 28/02/2012 12:19 pm
Well, not quite. The threaded portion will be narrower on a fixed hub than the freewheel, 'cos fixed cogs aren't as wide and a fixed hub also needs to accomodate the external smaller diameter thread for the lockring.
It'll still be fine though.
Posted : 28/02/2012 12:21 pm
The reason for the lock ring is to stop the sprocket unwinding when you try and do a rear wheel skid. As that is impossible on a freewheel it should be fine but the thread is narrower so there will be less thread enagement. Probably not an issue.
Posted : 28/02/2012 1:13 pm
not an issue on the woods kiss off disc as it's just as wide on the threaded section as surly or salsa singlespeed hub.
Posted : 28/02/2012 10:47 pm
