I’m 5’7″ with 31″ inseam which I assume gives me a shortish torso. My biggest issue is getting right behind the saddle on steep descents, even with it dropped a reasonable way. I had a 17″ P7 that really was too long, swapped it out for a 14″ On-one 456.
However, at the time of order I didn’t realise the ETT on the 14″ is a full 1.5″ shorter than the 16″, even though there is only 0.5″ between the 16″/18″ and 18″/20″. Nevertheless, I would probably be happy with this setup, though I run an inline post with 80mm stem to keep the front wheel down on steep climbs.
Looks like a 14″ Ragley might quench my thirst for perfection. Brant, I remember you mentioned its ETT was 22.5″ in another thread, do you have numbers for its stack, reach and headtube length? I’ve actually just bought a 2nd hand 16″ mmmBop frame cause I got a bargain Revelation with 1.5″ steerer and I couldn’t wait until early 2011 to use it… …even if it might be too big
