Hi People,
I ride an old Cove Hustler and it appears the RP3 is making a creaking noise when pressure is applied. I thought it was the linkage but after removing the shock this seems really plush (obviously I can't apply the same amount of pressure to this as the shock is removed). I've also looked for cable rub and the bushings seem tight. Bottom bracket seems ok and I have removed seat post too and applied pressure on top tube. I also fitted new seals and oil yesterday. Still no joy. The shock seems to work fine other than this, am I being picky? I just like to keep noise to a minimum.
I'm contemplating buying a new or used RP3/RP23 but need to iron this out before I pony up the cash. Any other Hustler/RP3/23 owners had this with any inside info or tips? Any thoughts people. Its a real sh*tter!
Thanks
