Hey there,
I'm looking at replacing the RP2 on my 08 Trance X, but just need some help first.
Can somebody or a few of you check what compression and rebound tune your shock has on your frame, then post up your results?
Cheers, Grant.
Hey there,
Cheers, Grant.
The shock is a non standard size as well so be careful if you buy one off the shelf
08 is 6.5" X 1.5" so a standard 165mm X 38mm.
Well mine on my 08 trance x is a 7.25" x 1.75"
Ah!
the X1, X0 and Cypher models were different from memory, these are 7.250" X 1.750" where as plain trance ,1,2 and 3 are the standard fitment. So an 185mm X 44.5mm is needed.
In my defence I haven't finished my first coffee yet
I'm all over the dimensions of the shock, both Fox and RS sell there gear in the right size direct from the factory now.
Thanks for the info.
Anyone got some shock specs?
You must log in to post.
