Washer
10.30×0.38mm
15.25×0.25mm
22.85×0.38mm
22.85×0.38mm
22.85×0.38mm COMPRESSION
12.70×0.25mm
20.25×0.25mm
22.85×0.25mm
Piston
17.85×0.38mm
17.85×0.38mm
17.85×0.38mm
15.25×0.25mm
15.25×0.25mm REBOUND
12.70×0.25mm
12.70×0.25mm
10.30×0.38mm
Small Washer
The above list is a pretty standard list of shims that I use on our race dampers. The 2 shims nearest the piston on the compression stack control the low speed then the next is a spacer. The spacer is next and this gives you a softer low speed before they then hit the next shims. The next shims are the high speed control. On the rebound side there is no spacer shim so there is a lot more progression and gives you more low speed damping. The 3 x 17.85 dia shims are pretty standard as a way to get a lot of low speed control.
Probably not much help but if you can find the shims to match the general idea of the above stack then you wont be far wrong.
