Just arrived in Les Gets, bike out of car and on first run the forks are making a right old clunk. The forks are Float R’s, less than a year old, and have done very few miles.
On further inspection the fork is tearing through the first 25-50mm of the rebound stroke with no damping, the rebound then cuts in, which is causing the ‘clunk’. The fork understandably doesn’t track the ground.
The bike has in a car on its side, so I’m thinking that there is air in the damper (not FIT but old school), but despite whipping the air out and having a good mess around, I can’t sort it. The Les Gets LBS has swapped the oil this afternoon, but to no avail. ‘
Totally gutted as the bike was built for trips like this and it rides like a sack of crash inducing crap. I’m sure its air or something minor in the damper – the fork was fine in the UK, but after travel is screwed.
Any ideas? Is there a procedure for reseting the damper?
The buys in the local shop have been a help, but I get the impression that anything beyond an oil change ain’t their bag, so failing any awesome tech tips, if anyone can recommend a good Fox dealer in the Portes Du Soleil I’d be chuffed. I’d be happy just to replace the entire damper, but I doubt anyone here will have them in stock. The shop I’m dealing with here don’t (although they are happy to sell me a new set of 36’s LOL
