Four4th Lights
[Closed] Four4th Lights
 Nor
[#3165536]
Has anyone got experience with these lights? I have been trying to compare the Genesis against lights like the Maxx-D. How do the low and high beams work out for riding, from what I can see is the high beam looks great but I am unsure if the low beam will just be to low to be useful.
Thanks!
Posted : 20/09/2011 12:42 pm
I have a set, not sure of the name but its the one with 4 XPG's.
An excellent bar light, lots of floodlight and great in the woods/singletrack it can look a little short on distance when out in the open. I use it with a joystick helmet light and that works well as the joystick adds a bit more distance (but without the same amount of all around light)
I've used mine for over a year & no dramas
Posted : 20/09/2011 12:52 pm
Currently running a 3 spot Genesis on my helmet and it works well for me on the mid setting and is great on hi.
Also running a Holy Moses on the bars which provides a good flood.
Plenty of people in our group are running Four4th lights with no issues so they are recommended!
Posted : 20/09/2011 1:05 pm
 Nor
Thanks for the responses. how do you find the run times between the Holy Moses and Genesis?
Posted : 20/09/2011 1:34 pm
They're tiny, they make the DX bastid look like those 7" and 9" headlamps cars and motorbikes used to come with!
Posted : 20/09/2011 1:45 pm
It's not really a fair comparison. Running the genesis with a aller battery.
I did a ride earlier this year with the two Genesis on the lid and Moses on the bar. Running on low power and upping it for singletrack and I was out for about 6 hours with no issue. Happy running full power for about 2hrs 30 without issue.
Go with Dels recommendations and you should be fine.
And yes - they are tiny!
Posted : 20/09/2011 2:26 pm
What are the run times on th eholly moses for different settings...? Is it really 2500 lumens on high...? !!!!
Posted : 23/09/2011 7:46 pm
