Flyingdales moor - ...
[Closed] Flyingdales moor - right of way question
[#2594058]
are you (legally) allowed to cycle on this track? 😕
http://www.streetmap.co.uk/map.srf?x=492215&y=499270&z=120&sv=492215,499270&st=4&ar=y&mapp=map.srf&searchp=ids.srf&dn=772&ax=492215&ay=499270&lm=0
Thanks
Posted : 24/03/2011 1:06 pm
It's not in red...no you can't
Posted : 24/03/2011 1:32 pm
No.
I wouldn't worry about it though; it's open moorland.
Posted : 24/03/2011 1:33 pm
ar$e. wondered if it was a permissive route, as seen people using it.
what is the best way to end the C2C ride (from Stony Leas)?
Thanks.
Posted : 24/03/2011 1:37 pm
There's likely to be grouse, lapwings, curlew, snipe etc nesting on the ground on the moors right now so if it's not a ROW I'd avoid it.
Posted : 24/03/2011 1:40 pm
Its just a 'track', you have no legal right to ride it, but as there is no specific bylaw in place to specifically prevent you riding it, anyone is welcome to - which is why you're seen people ride it. I'd happily ride it unless told not to by the landowner or their agent.
If it is a well established track, you probably won't distub nesting birds.
A right of way is just that - legally protected right of passage, just becuase it isn't a ROW it dosn't mean you can't use it.
Posted : 24/03/2011 2:29 pm
 gil_
I regularly ride the trail in the other direction from Lilla Howe following Little Eller Beck and then onto Simon Howe, beautiful bit of trail
I have met National park rangers on the trail on several occasions and asked the same question, three times I have been greeted with blank faces and "you'll be fine" just give way to walkers...
The trail you are talking about is only an extension of this, I would say the section you're looking at can get very wet and quite overgrown later in the year
Hope that helps
Posted : 24/03/2011 2:45 pm
 cp
yep, google sat view suggests it's a very well defined track.
looking at it in 1:25,000, it's a 'path', so doesn't techincally have a right of way, but that doesn't mean you can't use it, no matter whether you're walking or riding. Public use it, they can just be asked not to if a land owner tells them to clear off... which is HIGHLY unlikely.
I'd have no problem using it.
Posted : 24/03/2011 2:50 pm
thats great, thanks for you help 😀
Posted : 24/03/2011 3:37 pm
