So I have a trek with F-Series 120RL Fox forks, what is the difference between the f-series and the Floats? Is the F-Series simply the OEM fork and the float aftermarket?
Are there any actual differences between the two forks?
Bike Forum
Float -> F-Series Whats the difference?
Posted 8 months ago #
F series, generally have a lighter chassis
Posted 8 months ago # -
F series are more badass..
F-series is better, by 0.7.
New ones look like the float just named F. Old ones were different as the F's had a lighter build and terralogic, whereas floats just had normal damping control and blowoff(if you had RLC)
I don't think Terralogic was specifically an F thing. It was more to do with lighter weight pared down lowers and crowns compared to Float32's IIRC.
The F is for female. You've got lady forks.
You're probably right for the 32's, I was thinking about the older than that ones pre '32' label. Come to think of it, it probably wasn't even called terralogic then either, but I do recall one of the differences in the Fxx ones was that they had some sort of inertia valve thingamy as that was the reason I avoided them.
No, they're definately the lady version.
Like the F-Series Canyonero.
F is for fooked quicker.....because they are Fox
if your normal Floats, if fat 36's and a complete heffer 40's?
if you don't weigh much F's.Posted 8 months ago # -
The way to tell visually is F series have a hollow brace, floats have a webbed brace
Terralogic forks had an X at the end of the name.
The boring answer, as far as I am aware...
They are generally the same, but the f series is for the shorter travel versions and will have a bit more material machined off around the crown etc.
I thought terralogic were RLT??
So essentially the F-Series has a plain brace and the float has a webbed brace meaning the float is heavier- but I guess a little stiffer.
Even Fox's tech website seems confused, I have 120mm travel F-Series forks but these aren't mentioned; just the F-100 or the Float 120.
I'd like to get a guide on changing the oil and cleaning the dust wipers and while I guess it's the same between floats and f-series it'd be nice to be sure! (I've seen the MOJO video, which was helpful)
Not the case, sorry
My F29s have a webbed brace
Travel specific dampers IIRC in the F-Series so not possible to change/space travel. That along with the lowers is the only difference I'm aware of?
theroadwarrior, the internals are pretty much the same for F series and Float 32s. If you follow the servicing instructions for float 32 forks you'll be absolutely fine I promise!
How does such an interminably prosaic thread like this keep spluttering on?
For 3 days now...
If I ask something it usually disappears off the front page in less than 5 minutes
For 3 days now...
...perhaps it's the language you use?
Oddly enough my Hayes brake question has elicted 1 tentative answer since sunday.
Reply
You must log in to post.
