Flat Pedals - Pick ...
[Closed] Flat Pedals - Pick Some For Me!!!
[#2014591]
In the market for some flat pedals but I cant make a decision!!
The options I have are:
- Funn Soljam Viper
- Wellgo B54/B25/B27
- Easton Flatboy
- Superstar Nano
- Shimano DX
What would the STW massive choose, any other options that I have missed?
Ta in advance.
Posted : 22/09/2010 9:58 am
 DT78
Nanos. In fact I have a spare set, in black you can have for £25 posted.
Posted : 22/09/2010 10:02 am
MBR do a quick review of flat pedals this month.
The Nanos are a great choice based on grip and weight.
Posted : 22/09/2010 10:04 am
superstar
Posted : 22/09/2010 10:13 am
Ive had
DMRv12
Wellgo B54 & B27
Superstar Nano
Shimano DX
Nanos are the best for me, thinnerist, good grip without long studs, nice wide platform. Only used on my DH bike though, not sure on bearing lastingness.
Shimano are thick and small platform but last ages.
Wellgo good and cheap, decent pins and OK thinnisity best VFM. I have some on my HT.
DMRs, didnt rate them, not sure what the fuss isabout.
 GW
depends how you ride, Nanos are a nice shape and well made but the axles are def not upto hard use.
Posted : 22/09/2010 10:14 am
Burgtech penthouse flats
Probably the last pair of pedals I will ever have to buy, got em in disco camo so they clash nicely with everything 😀
+1 on the Burgtec's.
Bomb proof, big platform, and plenty of bling...
Posted : 22/09/2010 10:16 am
DT78, what model have you got?
Posted : 22/09/2010 10:18 am
I've always used the cheapest wellgos you can buy (something like a tenner) and never had any problems with them. That was on my bmx as well as mtbs.
Posted : 22/09/2010 10:22 am
Gussett Slim Jims are worth a look. Very happy with mine (cartridge bearing version) now I've worked out I need to loctite the pins in place.
Posted : 22/09/2010 10:25 am
 jedi
i realy like azonic afames. mg1's are too small and soft for me
Posted : 22/09/2010 10:29 am
I only have around size 8 feet so size probably wouldnt be to much of an issue although they're quite wide. Can the mg1s take some decent abuse then?
Posted : 22/09/2010 10:31 am
Burgtecs and other high ends pedals are too much money IMO for the amount of stick they get, you can get 3/4 pairs of cheaper ones.
Posted : 22/09/2010 10:34 am
In fact I just this minute got a pair of sealed bearing Slim Jims off CRC for £28 - and they're only £32 if you don't want green ones.
[url= http://www.chainreactioncycles.com/Models.aspx?PartnerID=79&ModelID=17286 ]http://www.chainreactioncycles.com/Models.aspx?PartnerID=79&ModelID=17286[/url]
Not supposed to be buying bike bits at the moment, but I like my other set so much more than my Wellgos and DMRs that I couldn't resist.
Posted : 22/09/2010 10:36 am
I'd say no. Only pedal I've ever managed to kill.
Liek Jedi said, too soft.
Posted : 22/09/2010 10:38 am
Yes, but inspite of having broken/worn out almost every other component on my bike I've not even touched them, my only gripe is the weight, which has been solved for the MK3's.
Posted : 22/09/2010 10:40 am
 GW
Sorry to tell you chaka but slimjims are pretty shit TBH but if you are happy with them the EBC branded ones are only £19.99 (in black)
Posted : 22/09/2010 10:41 am
Wellgo B54's have been excellent for me.
Posted : 22/09/2010 10:42 am
Superstar here.
superstar are excellent
why pay more?
Posted : 22/09/2010 10:45 am
I chose Nanos. I'm happy with that choice.
Posted : 22/09/2010 10:53 am
Been running DMRv12, Shimano DX and Easton Flatboys for a few years, all of them great pedals, the DMR's squeek like mad if you don't grease them on a regular basis, DX's bearings are very smooth but I find the pins a little small, Easton Flatboys are a good solid pedal but big and a little heavy, I'd probably go for the flat boys though. What I would say it get a decent pairs of shoes, I've had the Shimano AM40's and the sole has been shredded to bits, going to give five tens a try. And be prepared for a few extra holes in your shins and calves.
No, that's OK, I don't mind.
Why you think so though? Genuinely v impressed with mine.
Posted : 22/09/2010 10:59 am
I think MG-1s are ace... but then.. If I was clattering into things often enough to wreck my pedals I would be seriously questioning my ridng style..
unless you are riding trials or rhinocore they are fine..
Posted : 22/09/2010 11:03 am
I put MG1s on my GF's bike and they are nowhere near as good as the SS ones imo.
Posted : 22/09/2010 11:09 am
 GW
I hope for your sake you don't ride techy descents in very muddy conditions often
Firstly the stupid recesses around the pins fill with mud rendering the pins almost useless and to top it off the outer edge is has cut aways rather than a raised edge meaning your feet have a nice slope to slide off to the outside.
They are a truely awful design.. they can work OK if you replace the outer edge pins for longer ones though, I still use a set on one BMX where wet weather grip isn't an issue and moving foot position easliy is a benefit.
Posted : 22/09/2010 11:11 am
Seems like a mixed response, looks like the nano shading it, DX look ok but smallish platform but should be OK for me, wellgo's seem like a decent low price option. If I decided on the nanos what version should I go for, thru pin or normal grub screw version?
Thanks for your answers and reasoning.
Posted : 22/09/2010 11:22 am
5050 XX. Not the single X version
Had mine for about 3 years or so.
Got some good rock scars on them, been through everything rain, mud, sleet, snow, and the bearings are still fine.
Great with fivetens
 jedi
i got azonic aframes on bottlerocket/demo9 and bmx and left the mg1s on the hummer. i need to find another model as aframes are not made anymoree iirc 🙁
Posted : 22/09/2010 11:39 am
DT78, if no one has taken you up on those Nanos, I am interested
Posted : 22/09/2010 11:56 am
On a budget: Wellgo MG1
No expense spared: Burgtec Penthouse Flats
I have both and like both. But to be honest, when I use my Vans with the 5-10 rubber soles they're both as good as each other.
Posted : 22/09/2010 12:00 pm
 ART
Nanos - stop asking already. On all my bikes now after ditching the shite DMR ones. 10% off at the mo too, probably off the back of that lovely MBR review. 😉
Posted : 22/09/2010 12:05 pm
GW - Interesting thanks. I had long pins from start so not noticed these problems.
Just seen SSC are flogging those Nanos a bit cheaper now so might get them instead for £10 more/100g lighter anyway.
Posted : 22/09/2010 12:07 pm
Jedi, you not used the Azonic 420's?
DT78, if they're grub screw version I will most likely takke them, if not then mattjng feel free!
i agree with scruff re: DMR pedals, dont see what the fuss is all about them, having used a pair i wasnt all that impressed with their performance given the price.
i have a pair of wellgo b25 on my freeride rig and they are really good for the price so they get the VFM thumbs up. i've had them for over 4 years and they still look new.
i have a pair of easton cullys on my DH rig which i have to say are the absolute dog's knackers. ok they cost a fair bit to buy and i'm not sure if theyre still in production but performance wise i cannot fault them at all. superbly strong, comfortable and grippy as hell no matter what the conditions are.
Posted : 22/09/2010 12:24 pm
Outland if on a budget (I did a review, look in my post history) or Canfield for the best
Posted : 22/09/2010 12:29 pm
Have your edge pins stayed in place? I've lost a few of mine and they don't look replaceable. Do you know if they are?
Posted : 22/09/2010 12:31 pm
MrNutt, read your review, what other pedals have you used to compare them to?
Posted : 22/09/2010 12:32 pm
Wellgo mag1's were my preference before the outlands, with the outlands your feet don't become "light on the pedals" at the top of the stroke
Posted : 22/09/2010 12:39 pm
Nano's here too, but from here http://www.readytoridecycles.co.uk/ht-components-magnesium-mn06ss-nano-flat-pedal-277-p.asp
Made by HT Components in the same factory that make Superstar and Nuke Proof pedals (as far as I'm aware). Cheaper than Superstar, and FAR cheaper than Nuke Proof 😉
Posted : 22/09/2010 12:45 pm
MrNutt, the grip is pretty good then, I see no pins on the outside edge, is this noticeable in use?
Posted : 22/09/2010 12:47 pm
GW - Member
thats why you run longer pins in gusset slim jims. double concave shape is nice and the longer pins mean even in the shittyest slop i can razz without slipping and having to wear special shoes.
definitely recommended. but you do need the longer pins.
just goes to show that pedals are a personal thing. i've tried loads of the ones recommended above but these have been the best for me.
Posted : 22/09/2010 12:52 pm
Superstar nano's for me. Bought them for the alps in July and i think they're great. Look pimp too!
Posted : 22/09/2010 12:53 pm
