First aid kit conte...
[Closed] First aid kit contents
 ade
[#3021728]
Do you keep a first aid kit in your packs when you're riding? If so, what's in it? I've just got a [url= http://www.wiggle.co.uk/ortlieb-first-aid-kit-medium ]handy Ortleib kit[/url] but wondering if I should add anything to it (within reason - an ER nurse wouldn't fit).
Posted : 06/08/2011 1:24 pm
so that contains:
1 roll sticking plaster, 25mm wide
2 fleece compresses, 10 x 10cm
1 elastic bandage, 60cm x 40mm with 2 clamps
1 gauze bandage, 60cm x 40mm
1 pressure bandage, 80cm x 100mm
12 plaster, 70 x 20m
I carry on top of that:
steri strips
scissors
polythene inspection gloves
plaster spray (good for grazes)
cheap PAYG mobile with credit
that will cover most things
Posted : 06/08/2011 1:29 pm
Clean hankie, duct tape. The rest is superfluous.
Posted : 06/08/2011 1:32 pm
Knowledge cricky - knowledge 🙂
Have a search this has been covered on here a few times.
The crucial point is that there is a very limited set of injuries where having a kit makes a significant difference. Major injuries - call the pros, minor ones - carry on. Occasionally you might be able to make the difference between carrying on and not or make things more comfortable
Posted : 06/08/2011 2:30 pm
Just a large dose of common sense.
Posted : 06/08/2011 2:32 pm
Gin.
Anything else just makes you look soft.
Posted : 06/08/2011 2:44 pm
tick remover
Posted : 06/08/2011 3:12 pm
Roll of tape
Couple of sealed sterile gauze patches
Water
Service revolver if it's serious
Covers most stuff
Posted : 06/08/2011 3:23 pm
