Fat Question .... 4...
[Closed] Fat Question .... 48mm too narrow for a Larry?
[#3381650]
As above.
Have a 100m spaced front wheel with a 48mm rim.
Thinking about upping tyre girth to a Larry. but wondering if the tyre will be okay on a narrower than normal (for the tyre) rim.
Any help would be much appreciated 🙂
Posted : 23/11/2011 11:28 am
Tyre will fit the rim fine, you just won't get the full fat effect ... it will still be a very wide tyre though 😉
Posted : 23/11/2011 11:58 am
Do you mean that I won't get away with running very low pressures?
Posted : 23/11/2011 12:05 pm
No, you'll still be able to run low pressures. I mean that a 48mm rim won't 'pull' the tyre out as much as it would if fitted to a wider rim.
Posted : 23/11/2011 9:57 pm
it'll be fine but not the full fat effect as Norm says
Posted : 23/11/2011 10:08 pm
