FAO doubters II (ca...
[Closed] FAO doubters II (carbon brake mount & potential FLAME-AGEDDON content)
[#2734549]
Yeah poor finish etc but do you think it will work? Will post up later, out for a test ride now.
[url= http://farm6.static.flickr.com/5026/5703801891_1b4a0c1cd1_z.jp g" target="_blank">http://farm6.static.flickr.com/5026/5703801891_1b4a0c1cd1_z.jp g"/> [/img][/url]
[url= [/url] by [url= http://www.flickr.com/people/7693620@N05/ ]alan cole[/url], on Flickr
[url= http://farm4.static.flickr.com/3647/5704118849_fe19c080c2_z.jp g" target="_blank">http://farm4.static.flickr.com/3647/5704118849_fe19c080c2_z.jp g"/> [/img][/url]
Posted : 09/05/2011 8:57 pm
You've got your forks on back-to-front mister!
Posted : 09/05/2011 8:58 pm
Yeah, but you're a rubbish engineer, looks like a spoon, I know better, why not v's, let me draw you a diagram.
Did I miss anything?
Posted : 09/05/2011 8:59 pm
 Nick
Is that a disc mount held on by gaffer tape?
Where's the spoon...?
Posted : 09/05/2011 9:00 pm
 ton
you will die............. 8)
 Keef
..........horribly
Posted : 09/05/2011 9:02 pm
 ojom
Oh.
So you won't make the stag or the wedding then?
We will send pics to the ward.
Posted : 09/05/2011 9:04 pm
Are the braking forces going to want to pull that off (no s****ing at the back) rather than push it into the fork?
coooeyyyyyyyyyy
Posted : 09/05/2011 9:05 pm
good luck : /
You'd better still be alive when I pop up to Edburg in the summer Al
Posted : 09/05/2011 9:12 pm
 Bez
Boy, that's there is the ugliest goddam thing I've seen since yo' mamma's come face.
Posted : 09/05/2011 9:20 pm
"More middle class than the rest of stw put together" Bez doing street jive, a true gem!
Posted : 09/05/2011 9:22 pm
i don't think i've seen bez post on here for about 5 years and then that gem appears.
brilliant
Posted : 09/05/2011 9:26 pm
Oh god not again, can you hang fire for a mo, I'm all out of tea bags and need to plump up the cushions, I have a feeling this could be a long one
Seriously though, i appreciate you may be having fun playing at being an engineer but what is this experimentation costing you not just in money and time but in potentially ruined parts?
Posted : 09/05/2011 9:29 pm
Are you really [s]stupid[/s] brave enough to ride that?
Posted : 09/05/2011 9:31 pm
Look like electrical tape? Just to confirm, you have the disc on the drive side of the bike, on the front?
Surely the rotational forces will just rip the caliper away from the fork, rather than push it into the leg?
Be careful, the last thing STW needs is a martyr.
Posted : 09/05/2011 9:34 pm
What can possibly go right?
Posted : 09/05/2011 9:40 pm
Has he got his ambulance ride yet?
 LsD
It's wrapped all the way around the fork, it might work and it might actually work quite well if you've done it right. The wrap could spread the load to the back of the fork quite effectively and apply it to the fork over quite a large area. Doing it the other way would produce two point loads that could be too much for the fork possibly.
Real suck it and see territory though, good luck!
Posted : 09/05/2011 9:45 pm
LOLs.
well done the geniuses who've spotted it's on the RH lag. You lot are truly experts in engineering....[i]with x-ray vision[/i] into computer screens to comment on the structure!
Well done, go you!
Multi-layer full carbon wrap cured under compression. I've not worked out a way of compressing it while preserving a nice finish, I'll just sand & lacquer it if it works out.
Thanks for seeing the idea behind it PR 😀
why has he put it on the front of the right fork leg not hte back of the left as usual? And the rotor is on backwards...intend rotation is marked....see no reason to change that even if the caliper is mounted on the from of the right leg....rotation is chosen so the top of the disc spokes sweep crud down and out, rather than up and collect where spoke hits braking surface.
Posted : 09/05/2011 9:48 pm
 CHB
Noooooo!
I thought it was a proper disc ready carbon fork where the heat from the disc had caused the flamageddon!
Can't wait to see it on next years Darwin awards.
Posted : 09/05/2011 9:50 pm
Whoa!
You've attached it with....
[i]tin foil??!!??[/i]
Posted : 09/05/2011 9:52 pm
I am loling at the thread in general. I really have no idea whether this will work, so do PLEASE let us know, won't you?
how did you align the brake tabs?
Posted : 09/05/2011 9:54 pm
[url= http://www.cotic.co.uk/geek/#ROADHOG_discmount ]Cy was there a while back..[/url]
I think it will stay on, but my concern is where the load goes into the forks (which weren't designed to dissipate it from where it's now coming from).
Yes, no easy way of a good finish on the outside when you compress the fibre. How was that done? Vacuum? Tape?
Posted : 09/05/2011 9:55 pm
Its a centrelock rotor. If it was the NDS the rotation would be right but when the wheel is flipped to put the rotor on the DS the rotation is then wrong, but can't be changed like a 6 bolt rotor.
I give this a better chance than the rear one. Though the consequences of failure are potentially higher!!! 😯
Posted : 09/05/2011 9:56 pm
ChunkyMTB - Member
BB7 with std. washers on the mount.
richmars - PTFE bag and string 😎
Do you lot really think the rotational direction matters?
Posted : 09/05/2011 10:01 pm
Have seen your latest work can i just apologise for being a doubter.
Posted : 09/05/2011 10:03 pm
45 mins between 'going out for a test ride' and posting again. Did it last longer than the rear, or did you just not use the front brake? Attention-seeking whore aside, I'm enjoying these threads btw.
Posted : 09/05/2011 10:05 pm
ah centre lock, didn't know they couldn't be swapped....why do they even bother marking the direction of travel then if they have a poke-yoke?
can't wait to see the result of this one...so long as Al doesn't hurt himself that is.
Posted : 09/05/2011 10:07 pm
No, just trying to explain it. I'd be more worried about ripping the leg off a fork not designed to take a disc mount 😉
Fair play though interested to see if it works!
The disc rotation direction would be the least of my worries
Posted : 09/05/2011 10:08 pm
please tell me more about how you applied the compressionz?
Posted : 09/05/2011 10:09 pm
Can you please post a vid again al
Ah yes....GavinB has it. No lawyer tabs on the dropouts and Al doesn't want to shoot his wheel from beneath him, which is very sensible....yet he tris this 🙄
Posted : 09/05/2011 10:10 pm
crispedwheel - Member
Seems to work fine on a stoppie-tastic test ride, I thought I'd let the thread run a bit before telling y'all.
I could easily not have bothered posting this up, and I knew I'd get the piss taken, but it's a bike forum, and I guess I thought someone might be interested in someone who's actually trying to make bike bits. But hey! I guess no one will be interested in my next project....the ultimate mtb!
Posted : 09/05/2011 10:11 pm
Ultimate = Last.
Alas, for you, this might be too true 🙂
Posted : 09/05/2011 10:13 pm
disc rotation only matters a tiny ickle bit on very muddy rides. Cack will collect at the top of the spokes on the dis, that's all....slightly affectng braking power.
So did it work?
edit, ah so it did...for now 😉 keep an eye out for cracks at the top of the fork leg, that's where the bnding moment will be greatest, that's where it will fail.
Eh? Quote me in full please - you missed off 'I'm enjoying these threads btw' from the end of that. Precisely because, you know, it's about bikes and modifying them. Glad to hear it's working so far.
Posted : 09/05/2011 10:15 pm
For compression (if there's a next time) you can try insulating tape, wound sticky side out (so it sticks to itself). Get it really tight and prick lots of holes in it so the excess glue can seep out.
Posted : 09/05/2011 10:21 pm
