Eventually I'm...
[Closed] Eventually I'm converted properly.
[#2300711]
[url= http://farm6.static.flickr.com/5129/5277510980_aef01c9d24.jp g" target="_blank">http://farm6.static.flickr.com/5129/5277510980_aef01c9d24.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/rlepecha/5277510980/ ]one is the way[/url] by [url= http://www.flickr.com/people/rlepecha/ ]rlepecha[/url], on Flickr
[url= http://farm6.static.flickr.com/5242/5277509608_298a054f61.jp g" target="_blank">http://farm6.static.flickr.com/5242/5277509608_298a054f61.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/rlepecha/5277509608/ ]100_3567[/url] by [url= http://www.flickr.com/people/rlepecha/ ]rlepecha[/url], on Flickr
[url= http://farm6.static.flickr.com/5004/5276899481_3f03856dc8.jp g" target="_blank">http://farm6.static.flickr.com/5004/5276899481_3f03856dc8.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/rlepecha/5276899481/ ]100_3563[/url] by [url= http://www.flickr.com/people/rlepecha/ ]rlepecha[/url], on Flickr
No chain slip, completely smooth. Had to modify the tensioner slightly with a file to allow it to push up. I did think i was just getting 1 half link, but winstanleys bmx sent me a full Gusset Slink for £1.99
Posted : 20/12/2010 5:21 pm
Me likey.
Posted : 20/12/2010 5:47 pm
most bargainaceous!
The pics look good. I really like those halflink chains.
Posted : 20/12/2010 5:52 pm
I hate to point it out, but you're running your half link the wrong way around. Rounded/outer edge should be the leading edge.
Posted : 20/12/2010 5:53 pm
Wot he said- you'll need to turn your chain around for it to bend properly. Looks good though- do you need the tensioner with the 1/2link chain?
Posted : 20/12/2010 5:56 pm
I did think it was back to front but was too timid to post...
my Gusset half link chain weighed an absolute ton but always worked well.
Was a bugger to get in a chain tool though as it's so wide.
Posted : 20/12/2010 5:57 pm
it doesn't make any difference unless you're using it to grind as in bmx.
Posted : 20/12/2010 6:10 pm
Technically, why is it that the chain is 'wrong' that way round? I don't see it would make much difference, but wouldn't it run smoother over the tenioner the way he has it? Not disagreeing here, I just wondered why?
Posted : 20/12/2010 6:15 pm
I've never ordered something from winstanleys and actually received what I ordered. Does anyone know someone who works there?
Why? Is it faster?
Posted : 20/12/2010 6:18 pm
The reason half link chains should be run the opposite way is so that when the'yre being ground on a hard surface it's less likley to open up the outer link on the chain.
So wouldn't make a blind bit of difference with that setup.
Posted : 20/12/2010 6:24 pm
Foolish fashion follower.
Posted : 20/12/2010 6:32 pm
Depending on chainstay length, even a half link does not guarantee adequate tension.
Posted : 20/12/2010 7:31 pm
Exactly, I took another link out and the chain was too tight and wouldnt go on.
Posted : 23/12/2010 5:15 pm
 Pook
Ok singlespeeders - what happens if you bend your chainring?
Posted : 23/12/2010 5:38 pm
You die.
Posted : 23/12/2010 5:42 pm
You buy a new one.
Posted : 23/12/2010 5:47 pm
You smash your uts on your top-tube / stem and cry in a manly way
Posted : 23/12/2010 5:52 pm
beard catches in beer bottle cap on top of stem
Posted : 23/12/2010 6:56 pm
I dont know - what does happen if you bend your chain ring?
Awaits the punch line.....
Posted : 23/12/2010 7:05 pm
You buy a Middleburn Uno and it never happens again...
Posted : 23/12/2010 7:28 pm
If your chainring is bent you show it pictures of flirty little white Indfreewheels, and curvaccious woods hubs, It soon turns all hetro and stiff again 😉
Posted : 23/12/2010 8:23 pm
