Who looks after the cycle paths? Yesterday a tree was either almost blown down, or pulled down by neds. It is now almost totally blocking the path. Any idea who maintains the paths so that I can report this?
Bike Forum
Edinburgh cycle paths - maintence?
Posted 2 years ago #
Local council. ROW officer or dedicated cycle officer if you have one
http://www.edinburgh.gov.uk/internet/a-z/AZ_public_rights_of_way%3Binternal&ind=0
Posted 2 years ago # -
*Coughs*
That's "Cooncil"
The council?
Don't sustrans have a say, too? Although probably not for this type of stuff. Shut up, Jim.
Claire, speak to Nina. He has had similar issues, I am not sure if he got in touch with someone though about it.
I will do some digging.... one of the lads here is working with Sustrans 2 days a week.
BRB
cheers mark, will do. just thought it would be easier if someone had a contact. no-one in works appears to have a contact oddly enough. meantime i can practise my skillz trying to ride underneath the tree (til it completely falls down, probably on me!) that section could also do with some general tidying up - its so over grown with nettles and weeds that it makes it tricky to pass walkers/other riders without getting stung or wet!
Ok - it turns out that Tom here is a Sustrans Ranger and needs to know where it is so he can get it cleared. Co-ordinates if you please!
They could also take a look at Route 1 towards the Forth Bridge ?
The section that pops out alongside the A90 is all overgrown and could do with a good hacking back.Posted 2 years ago # -
i just contacted Cycling@edinburgh.gov.uk and they had it cleared pretty sharpish
Yay
Okay. The section of cycle path is by murrayfield. I don't know the name of the section of path, so here's a description. If you come along Baird drive (just off balgreen road) and head towards Murrayfield. Cross the bridge and turn right and go under the bridge. Just past the bridge is the tree - its still standing but leaning right over the path. The rest of the path takes you to the junction at westfield road/stevenson road and it pretty built up with barbed wire sections on the top of the wall. This section is pretty over grown.
Thanks
shall i copy it to the email address as well?
just email that to them, the guy was called chris and pretty helpful. my instructions to where the tree i needed shifted were more vague
IIRC they are under duties to keep roads etc clear for safety reasons so they should wort it ASAP
The WOL path is not Sustrans controlled apparently - Tom thinks it might be the council/waterway authority, drop them an email to find out.
If there sustrans sign then they are in charge but not otherwise. Politics eh?
have dropped the council an email, so hopefully will hear something back soon. thanks for the help
Al/Mark, do you have any suggestions for mudguards for my roadie commuter? When i bought it, they fitted mudguards, but after a few months, the rear one snapped. I bought ones from CRC but they don't fit, despite being the right size - think the mounts are in a different place. Its full length ones i'm after. Full length are a must for commuting...
SKS Chromoplastics. What size do you need?
I'm pretty sure they are the ones I've got - narrow, 700cc - 35mm. But they don't fit. I'll need to double check when I go home tonight, but 99% sure it’s the same ones. I don't know why they don't fit.
Do the fixing rub on the tyre? If so you need to go up a size to P45's
couldn't get to fit at all, never mind rub on the tyre! i shall double check tonight and let you know.
Bring em in if you like and let me have a go. I am proficient in pannier rack and mudguard installs these days!
Topic Closed
