dualit toaster help
[Closed] dualit toaster help
[#3089170]
where else would i turn for toaster advice??
bought a 6 slice vario toaster off ebay. it's orange, so we're very excited, and virtually new, it appears
it was listed as 'not working' but i know you can get spares so (hopefully) I got it cheap, and a little project for the evenings
am i right in thinking that measuring the resistance will tell me which elements are duds? has anyone else done this?
cheers
Pete
Posted : 27/08/2011 2:17 pm
You can get the spares direct from the Dualit website.
Posted : 27/08/2011 2:23 pm
actually i think it must be new-old-stock. it's never been used as there is not a single crumb inside. the serial number says it was made in 1996, and the elements appear to be a different design now. hopefully still compatible!
Posted : 27/08/2011 2:42 pm
Yes - No problem to test them with your meter. On the older ones just run your hand up and down. You'll spot the break. I think the newer ones are enclosed?
Simple enough inside and easy to replace.
Hth
Marko
** Normal H&S stuff applies here. Unplug it first.**
Posted : 27/08/2011 3:24 pm
