DT Swiss RWS skewer...
[Closed] DT Swiss RWS skewer question...
[#3916266]
Will this fit a standard 135mm QR hub? This model [url= http://www.justridingalong.com/rws-aluminium-bolt-through.html ]HERE[/url]....? I have a King ISO hub on my Enduro and would like to stiffen up the rear end a bit....
Posted : 26/04/2012 5:34 pm
MussEd thats a 10mm axle you'll so need 10mm adapters. DT Swiss do a 9mm version that will fit.
Here: - http://www.chainreactioncycles.com/Models.aspx?ModelID=81161
Posted : 26/04/2012 6:08 pm
No. A standard QR skewer is about 3-4mm dia, and that's a lot larger. Unless you can get adapter ends for your hub.
Posted : 26/04/2012 6:10 pm
