Viewing 11 posts - 1 through 11 (of 11 total)
  • Doh – leak in cold feed to sink. Compression or pushfit connectors?
  • sharkbait
    Found a pinhole leak on a cold feed to a sink which I need to fix today.
    Already got pipe but just deciding whether to go for push fit connectors or compression?
    Access is a bit limited as the hot supply is right next to the cold.
    Tiger6791
    Push fit are easy and work
    martinhutch
    Pushfit would be my choice unless you’re sticking it under a floor somewhere.
    neilwheel
    Pushfit work fine.
    allthepies
    Solder 😉
    Stoner
    the entirety of Casa del Stoner is plumbed with Hep2O pushfit. No problems.
    But they’re ugly as sin so never in sight.
    Oddly though, whenever I do work as a favour for anyone else I always use solder. go figure 😉
    Tiger6791
    I think it’s called ‘showing off’ 😀
    sharkbait
    Cheers Rachel 👿
    Fair enough, push fit it is. Never a dull moment….
    *makes note to keep some push fit fittings in the tool box just in case
    martinhutch
    Is it onto copper? Don’t need the inserts in that case.
    footflaps
    I solder everything and have only used one push fit adaptor, and that one is weeping ever so slightly. It’s behind a kitchen cupboard and I only noticed the drips when I was re-fitting the sink after sanding down the worktop to re-coat. It wasn’t a particularly cheap one either…
    trail_rat
    and to counter that my downstairs is all hep2 with push fits and inserts … upstairs is soldered copper
    the only leak i have had was in a copper bend where downstairs meets upstairs that had been soldered badly by a plumber – pin hole in the joint.
    Its now compression fitting due to not having soldering equipment handy at the time.
The topic ‘Doh – leak in cold feed to sink. Compression or pushfit connectors?’ is closed to new replies.
